Information about the really bad chargers that come with ebay flashlights
Hi,
I have ordered a Nitecore I2 charger, but until it arrives, I am stuck with one of those garbage $2 chinese ones.
It has a single red/green charge light in the corner and slots for 2 18650 batteries, with the text “forbit to invert”.
This is obviously not a long-term option, but until my I2 arrives I have some questions:
- Can I charge one battery at a time to avoid the issue of mixing batteries that have a different amount of charge left?
  • What happens if I put in both batteries, and one is slightly more drained/charged than the other?
thanks
Doing this outdoors with appropriate precautionary preparation?
Got a multimeter? Voltage — you have to know what it is.
Trust or mistrust — either way, verify!
I have few of those… and it will charge just fine, it won’t cause fire unless you leave the batteries charging for day or week at a time, until you get your nitecore… these will do :slight_smile:
I’ve had good luck with those. Shouldn’t be a problem. Just don’t leave them charging for long periods of time beyond what is needed.
I’ve got a cheapy 2 bay charger as well and it charges to 4.18v (DMM) every time. I dunno if there is even a point in buying a ‘pro’ charger.
4.18 ain’t bad…just undercharged, it’s when you pull your batteries off and they read 4.28 is the problem :wink:
I have a ‘forbids to reverse’ 2x 14500 charger too.
Works fine, stops at 4.2 Volts.
Got it with a nice SK86 clone incl. 2 crappy 14500s
I now use protected 14500 anyways, because AA / 14500 lights drain a LiPo to death…
I feel more relaxed though when I charge them in the i2.
Yes. Charging one at a time is a very good idea.
These junk chinese chargers might charge batteries in parallel. With two batteries that have different charge levels the higher battery will dump current into the lower one. Not the best idea.
Never leave junk chargers unattended. Unplug before leaving the room.
With a slight difference (okay, define ‘slight’) there’s no excessive current from the one to the other batt.
My first Chinese flashlight was a Police 3w with two UitraFirc 18650’s that charged in the light using a wall wart, nothing went pop or bang but then I only charged them once before doing a bit of reading.
From then on it’s been Nitecore i4v2 and a few Nitecore batteries plus some Samsung, Sanyo and Panasonic protected cells and a lot of Solarforce L2 series lights, they do all I want or need and I’m more than happy with them.
The original batteries - UitraFirc, not a misprint they are still being supplied to unsuspecting buyers - went to the recycle bin long ago.
It could so easily gone very wrong.
