I still haven’t picked out a name for this flashlight, so I’ll just call it LightCanon V2 for now (since it’s the second version of the original LightCanon I built)
I have some numbers:
1490 on the luxmeter in x100 mode.
That is 149 000 lux.
Distance is 5m from the front of the lens to the luxmeter:
The lens hood sticks out in front of the lens btw, that’s why it is slightly in front of the back of the laser.
*Calculated back to 1m:
3 730 000 cd*
Almost 4Mcd
This is just very initial testing, I will do some longer range tests soon to get more accuracy, but this is pretty incredible
Build log coming soon, I am very excited to show everyone how I did this!
Other than the “big fresnel lens in front of flashlight” builds, the only other light that comes close is the “Optik-Scheinwerfer” by a guy called Photon over on the german forum, which claims 3Mcd. The next best (I think) is the “Lance of RA” https://www.silentthunderordnance.com/blog/2017/3/13/lance-of-ra-product-introduction with 2.6Mcd.
Ok I went out tonight and took a more accurate measurement…
<1 lux moonlight ambient light level
50m measuring distance (my laser can’t do much farther than that unfortunately, otherwise I would have tried a 100-200m measurement)
Luxmeter in x10 mode, so ~1850 lux.
Result is 4.6Mcd
Yeah but I’m not sure if that loads the whole image into cache when the page loads, and then downscales it, or if it downscales first and then sends it to the user.
Here is a 3.78Mb image, let’s see how much data it actually uses:
EDIT:
before image: 62.2Mb
after image: 66.1Mb
Difference: 3.9Mb
So yeah it seems like the full images get loaded before resizing
It’s 60MB because of the other pics and two gifs I posted, which were 25MB each.
The difference before and after the pic was 3.9Mb, basically the full size of the pic, even though I set it to 800x600 in the forum.
If I do the build log will 50+ images at full size that would be like 200Mb, so I will need to down size them
If you use Imgur there’s no need to resize, I upload all of my review pictures at full resolution and add an “h” to the end of the file name before the .jpg.
H stands for huge and L for large, technically a thumbnail but more than enough for forum use.
If you check my reviews they all have decent resolution pictures that weight way less than 1MB, quality loss is near unnoticeable.
