Instantly dimming light?
So my c8 host with a 3.04a driver from drjones and some kind of xml2 from fasttech has been dimming on the highest mode after about 1.5seconds. It almost always does and then starts buzzing. Sometimes If I cycle it enough times it will stay on high for a few minutes without issue.
I have tried using 4 different types of cells, all in good condition and work no problem in my other 3.04a light.
Any idea what the issue could be?
First be sure you have a good ground between the driver and the pill.
I experienced something similar to this on an MT-G2 build using a 105c driver with the zener diode mod. I pulled the driver and inspected it with a magnifying glass and found a small piece of aluminum leftover from me drilling the pill to put in screws to hold down the emitter that was shorting the legs of one of the 7135 chips, I removed it and the light has continued to function properly since.
I also used the wrong solder flux once witch created a similar effect. I cleaned the flux with alcohol and the problem was gone.
