In for 1!
djozz already replied but…
…here’s an example from LCSC at ~1.1-1.2$ a pop in reasonable quantities
https://lcsc.com/product-detail/USB-Connectors_XKB-Enterprise-USB3-1-TYPE-C-FSABC_C319140.html
Problem is usually IPX7 or IPX8 Type-C connectors are also made as USB 3.1 Gen 2 compatible which drives up the cost (and complexity) unnecessarily.
For a flashlight you really don’t need a Type-C connector with 24 pins… You only need 6 pins.
I’m not good at rummaging through Alibaba but here’s a cheaper example
https://www.alibaba.com/product-detail/IP68-Waterproof-USB-Type-C-6PinFemale_62252784266.html
It even has “locating” pins so you can make a couple of holes in the PCB for it to sit in for some added support.
With these, like I said previously, the light needs to be designed around it and implemented correctly since the ingress protection comes from the o-ring which seals against the “chassis”.
If anyone is interested or perhaps wants some light reading before bed, here’s a link to Parker’s o-ring handbook. Almost 300 pages worth of fun.
https://www.parker.com/Literature/O-Ring%20Division%20Literature/ORD%205700.pdf
P.S. djozz, it would be a nice thing if this flashlight would follow the USB Type-C spec. By this I mean the connector needs to have 5.1k pull-down resistors between CC and GND so that USB Type-C chargers will actually charge the flashlight.
Thanks!
Thanks for the extra USB-C socket information, and for the Parker O-Ring Handbook link, best lockdown read ever :smiley:
I think I already asked for the USB-C charger support, Sofirn should be able to handle that because they had the request before for the LT1 and I believe already implemented it there in the next batch (not sure).
Interested
Interested
Interested
I’ll take one!
I’ll take 2 or 3
Interested.
Add me to the list!
Interested!
Interested
Interested in two if it has usb-c.
USB-C is planned. But to be frank, I have not had contact about this light since the crisis. But I think this light is still highly relevant so I see it coming off the ground at some point.
I am Frank (even by name :smiley: ). A light like this will always be relevant. And before every camping vacation I am looking for good muggle lights for the kids and my girl, but hardly ever succeed.
Would be a big plus for me if it had a warmer led than 5000k BTW,
For me too, but the 5000K LH351D was chosen because it is a great led that Sofirn already has in-house, and it pleases many. In a later phase we can maybe ask for other emitter options but at this point that is not relevant yet.
I finally stopped lurking and joined just to say INTERESTED for two to start. If they work out as well as they sound I could see buying a bunch more later. Would be perfect Christmas gifts in that $22 range with battery .
Thanks for the interest, I will update the list somewhere this week.
Add me to the list please. Most likely 1, but if executed properly ill grab a bunch for gifts.
