Was just trolling for any decent deals and stumbled across this light from Tmart. The only identifying marking on it is "SK-9210" which appears to me that it could be a Sipik. Big, well finned pill section, very thick walls with ample threading. Side-clicky switch in the right location and can be run in single or double 18650 formats. Heat sink ano in gold may be a turn off to some but should appeal to any Steelers fans out there. 55mm head and SMO reflector should make a half decent thrower.
Those wanting a side-clicky switch might want to give this one a shot. Who knows, it could be a diamond in the rough.
http://www.tmart.com/CREE-XMLT6-8W-1000-Lumen-5-Mode-LED-Flashlight-Black_p139077.html
Specifications
Key Features | LED Flashlight, Flashlight torch |
Emitter Type | CREE XM - LT6 |
Lumens | 1000 Lumens |
Power | 8W |
Bulb Quantity | 1 |
Light Color | White |
LED Lifespan | 100, 000 hours |
Modes | 5 |
Mode Arrangement | Hi > Mid > Lo > Strobe > SOS |
Lighting Distance | 450 m |
Battery Configuration | 2 x 18650 batteries |
Runtime | 3 hours |
Switch Type | Clicky / Clickie |
Switch Location | Side - cap |
Lens | Coated Glass Lens |
Reflector | Aluminum Smooth / SMO Reflector |
Material | Aluminum |
Color | Black |
Dimensions | 11.22" x 2.16" x 1.18" / (28.5 x 5.5 x 3) cm (L x Head Dia.x Body Dia.) |
Weight | 437g / 15.41oz |
