I’m in x 2
Pictures updated.
I like the design of the clip on the left. The hole can be used to thread onto a 1/4”–20 threaded screw. Think it’s a great idea making the pocket clip threadable. Mount it on any tripod.
I also like it with the bends of a clip from a CRK Sebenza.
Doesn’t look like enough room for two holes at the top if bent in similar fashion of a Sebenza clip.
Hope the design will work with a Zebralight SC62W. I want a different clip on mine.
Dimensions of nitecore ti clip. Make sure you use 1.05mm thick, like a McGizmo. The nitecore clip is too thin and flimsy.
Clip sizes
60.35mm long
12.40mm wide (at back)
0.75mm thick (flimsy nitecore clip)
1.05mm thick (McGizmo, use this)
3.0mm holes
7.0mm holes Center to Center. (curved clip).
Back to first bend, around 18mm
Back to last bend, around 50mm
Remember, use 1.05mm thick. Holes are 3mm wide and are 7mm centre to Center
These are for smaller bolts (2.5mm?). If you want McGizmo size, he uses 4/40 size bolts and has wide oval holes (see picture above)
Also if it’s a thick nitecore style clip, I’ll take 5.
I posted in the other thread, but can you put me down for a clip, possibly 2!
i am in for 2x, if it fits the Nitecore Ti lights
I’m in, for 2, perhaps 3, final design the deciding factor.
One thing clips need to have on them is a lanyard fastener. Not a place for the lanyard to fasten, but a quick fastener “on board”. The Convoy s2+ Red version lanyard steel hasp will clip onto this “convoy clip” in question. I do that when using the lanyard, but remove it when unneeded. It works fast and easily, unlike “threading the needle” with a soft lanyard loop.
But, it would be better if the clip was designed to hold a standard soft lanyard loop w/o metal hasp. That is, make a clip/hasp combo - a hasp built on the clip. I wont pay $6 for titanium, but will pay $6 for a great dual purpose clip.
Can you change me to 5 from 2. Pending final design but of you model the nitecore clip but thicker you have a winner.
I’m in for up to five, pending the final design.
I’m in for 3.
You can count me in for one. Thanks!
I’m in for 3
Put me in for 3.
Instead of two, can I get three more, bringing to a total of five. That is assuming the thickness is enough to resist bending or cracking like one of my stainless ones is doing. BTW, thanks for taking this on.
I am in for One for sure. Thanks!
I'm in for 4, pending final design and price.
For cutting and pasting:
ImA4Wheelr
ImA4Wheelr
ImA4Wheelr
ImA4Wheelr
In for two
Interested in 4 depending on design and included nuts/backing plate.
