Am planning to build a second 6s6p 25.2ah battery pack out of molicell p42a, I need help with the following questions
Ik that we have to match the cells based on their capacity and ir for grouping, but what’s the allowed ir and capacity variance range ( in terms of percentage) for cells in a same parallel group and between different parallel groups.
In the earlier pack I built, at the end of 4c continuous discharge rate from 24.9v to 19.1v, the pack temperature showed about 50-55°c and it takes like 30-40mins to cooldown to 45°c. Are these temperatures acceptable? Ambient temperature around 30-35°c
I don’t have any onboard BMS, so at what ∆v should I consider to balance charge my pack ( 15-30-40mv )? Usually the variation in my pack is about 30-40mv.
To increase the cycle life, is there any stop charge and discharge voltage range to follow while not giving up on the capacity. Can’t reduce the continuous discharge rate.
How are you measuring IR and Capacity. Lately when I build packs, I try to make my parallel rows equal in resistance( this way they should stay close to balanced when charging and discharging) If your cells are good the capacity difference is trivial.
No BMS / Risky (if you’re buying these cells new, a lot of money to ruin, BMS are cheap). In this case I’d set my discharge to stop around 18.6v . No matter if I have a BMS or not, most of the time I only charge to around 4.10v per cell (24.6v) As far as balancing current, as much as you can get out of your charger. Think about it, 6 cells in parallel with a 40mv current – Useless
I have a DCIR meter and I try to measure cells nominal voltage at around 3.6v ( nominal voltage ). Coming to the balance charging, 40mv I was talking about is the voltage difference between the Max and lowest volt groups in the pack. For a 6s6p pack is 40mv difference good enough and at what voltage difference when should I consider to balance charge my pack.
Secondly, how do you keep all your parallel packs at equal ir, is it the cells havings same exact or in a parallel pack or am I missing something (any tolerance variance)
40mv is totally acceptable ( talk about missing something, I did with this topic) I find they’ll get out of balance on the bottom end the further you drain them. Take you 36 cells and divide them up trying to make each set of 6 total resistance close as possible
I don’t know how much amp draw you’re planning on having. A lot of my packs are for Ebikes and Scooters, some draw 60-70 amps starting out and run at 25-30 amps. I manifold my + & - leads
