Since the jackals here became too cunny , i decided to make a IR flahslight, based on the C8 host
The best emitter that i found so far is Osram Oslon IR LED SFH47155
Most cameras or nightvision will respond better to 850nm, looks brighter. To human vision 850nm has a dim red glow viewed directly, 940nm doesn’t. I don’t know jackal’s visual range. No reason to expect it to be the same as humans.
Well, its more or less a hardware issue, my IR monocle works at 850 plus/minus 30, it wont work at 940-970
True, its not, they actualy sees it but they arent that frightened, tested myself
Well, i know Osram emitters, but they are only 3 w, was wondering if there is anything more powerful, like 10w, C8 host can handle it, it wont work 24/7, but for about 2-3mins tops - scanning area time
Actualy a good quality monocole wil help you see the beast at 150 m( actualy its eyes) without any other help, but this way you have to guess the beast body position
I will order some samples for evaluation anyway, wonder what would be the trowh capability of the C8 running with that Osram emitter…
If you want more throw then use the osram oslon in an aspherical zoom host. Uniquefire UF-T20 with IR osram oslon is often used by hunters for long range. Mtnelectronics carries it.
I am not an IR guru, but from all reports the Oslon 4715 and 4725 are the most popular emitters for hunting applications. Hunters tell me that with the UF-T20, and even a C8, they can see hundreds of yards with their night vision. The UF-T20 seems to be very popular with these guys.
They can be mounted on a Noctigon XP board because of the extra wide pads, but on a standard aluminum MCPCB they do not mount well at all. Bergquist makes a good 20mm aluminum MCPCB for the Oslons. You need to be aware that on the Oslons the center thermal pad is electrically conductive and is connected to the anode (LED +)...so if you use a Noctigon and the MCPCB makes contact with ground, you will have a direct short. With the aluminum MCPCB you don't have to worry about that since the thermal pad is electrically isolated.
Sure ofc, feedback is always wellcomed, i already ordered 3 pcs of that 850nm Osram, another 3 pcs of the 940nm Osram emitter, C8 hosts i have plenty, ordered 2 zoomies for hosts too, and will test on my 850 and 940 nm monocles
So the beta results would be in the Convoy C8 host, maybe early the next year, cause i have pleny of family things to do as all of us i presume( especialy by that time of the year)
About the low Uf….well, i have here 1 amp 17mm driver, that delivers 3.1v on XTE emitter, i will test it, Osram IR emitter max safe voltage is 3.5( info from the PDFs)
If someone in the EU is interested, got the emitters from Here, Led.de
Its faster, and the price isnt that rofl one….mouser asked nearly double price
And they use DHL premium for just 8 euros
Anyway, thanks again for the help and tips……
P.S
grantman321
Saw yesterday at least 40 kilos( nearly 90 pound) male jackal in the nearby woods, i think its an alfa male, havent seen that huge one ever, its nearly as big as a wolf…cant wait to get him
Pics will be posted( eventualy, i hope ) too( is it legal to post here pictures with dead animals?)
!! Whoa! Obviously, being in NC we don’t have jackals here… but jackals and coyotes are basically the same (and we have coyotes in literally every county in NC… and weird wolf/coyote hybrids, but that’s another story for another time). And that 90 pounds is pretty daggum huge for a coyote. Like you said — nearly as big as a wolf.
oslon 4715s/4725s cannot be mounted on direct thermal path mcpcb’s such as sinkpads or noctigons due to the anode and thermal slug being electrically connected. you will fry the emitter if attempted. ask me how i know.
kevin, i’m thinking about doing an IR T20 for shooting hogs. After looking at the thread here , i got a little confused. at post #22, djozz says he is using a 4715s and it is a parallel emitter then later marsh said the S was for the series emitter. So, the 4715S’s that RMM sells, am I correct to assume that they are series? How much current can they handle? On the thread I linked to, They are running in the upper 2’s.
I have no idea actually what the S means, but it is for a single cell. The can handle up to 3A on a Noctigon, but somewhere around 2.2A-2.5A is probably a better bet for longevity. I have no way of knowing how much the output wavelength shifts when these are overdriven like that.
You can electrically insulate the Noctigon with a very thin layer of Arctic Alumina. It isn't optimal thermally, but the surface area is big enough that it will still yield an improvement when overdriven at 2A vs. the Aluminum MCPCB at 1A.
Yes, just isolate the driver so that its ground ring does not connect with the host body. Might want to pot the driver so that it can shed heat through the potting compound to the host.
