I bought this S6 clone and the driver has a label on the positive spring side “RNX-R5”. I can tell you it has 3 sets of double stars with a blue PCB so like Nanjg drivers, I’m wondering, does it have mode customization? The driver is soldered twice to the pill so I haven’t seen the other side yet. I have measured L,M,H current as 0.16A (14), 0.45A (39)and 1.14A, it has last-mode memory and there is a slight delay in the light turning on when activated. Everything about it is typical of an S6 with an Omten switch. I already bought a Qlite driver from Mountain Electronics to push the XM-L2. So, for this RNX-R5, I’ll likely install it in an older light without modes.
Please let me know if you have some specs/experience with this driver.
Thanks!
Does it look anything like this? http://www.fasttech.com/products/1124801
Hi Comfy, I was thinking they would have the driver there too but no. Here is a picture:
I determined the driver does offer options depending on bridging the stars to ground.
table(table#posts).
|Star 0|Star 1|Star 2|Star 3|
|0.16|0.33|0.8|0.01|
|0.45|1.14|x|0.10|
|1.14|strobe|x|0.33|
|strobe|x|x|0.79|
|SOS|x|x|1.14|
If one looks closely, there is a strand of copper bridging star 3 (furthest to right). I can do without the flashy modes.
Once I take this apart, I might just stay with this driver if I can somehow make a direct drive path to the emitter and keep the less bright modes too. I hope this is possible. I’ll post some pics when I desolder the driver.
If I am reading that table right, star 3 is 5 mode, L>H, no blinky? how is the PWM?
Yes musicmagic, 5 modes without a blinker in the lot! As for PWM, I barely hear it in the mid modes and looked for it by using some fans and it’s almost imperceptible. I’ll be happy to check by other methods if you have a preference.
waving it around fast works for detecting high pwm, try that.
I like the S2 very much and I think your point is ‘get something bright & ready to go’. For a driver of choice to be swapped in AND the provided XM-L2 at about the same price as the quoted S2, I like the deal. The driver is a pleasant surprise and PWM really isn’t noticeable at any of the levels. I haven’t run it long enough to see how it handles low voltage but I’m checking it tonight.
I used up the last bit of juice that was left in a Sony US18650GR Fukushima STG (time for tossing) just to see if this driver has a low voltage indicator by flashes, flickers, whatever and it does. It starts slow, speeds up and eventually shuts off. End voltage was 2.83V.
