If you look on this site or any other flashlight site, you will see that all the cool people use protected 18650s. If you don’t, you are in the minority and perhaps considered at least somewhat less of a true flashoholic. Now maybe my reluctance to use 18650s is at least somewhat a rebellious reaction to this. But I also don’t care too much for the form factor of 18650 lights. And other batteries offer longer runtime (especially now that 26650s can be had with more than 5000mAH). So these days, I’m using NiMH lights and lights that use 14500 and 26650 (unprotected!) Li-Ion batteries. But I just don’t really care to join the whole 18650 party. Does this make me less of a flashoholic?
I use protected cells in lights without voltage monitor and unprotected cells in all other lights.
For my nanjg(4.4A)lights I use most of the time the LGD1 charged up to 4.37V…
I was reluctant for a year or so, but gave in. Honestly, if the multiple AA battery lights that we have now had been available 3 or 4 years ago when I got in to this money pit I might have never gotten in to the Lithium ions in the first place. Back then the 18650/ 2X CR123 lights were the only way to get the output I was after.
When an 18650 light is manufactured well, it’s a good combo. What I don’t like is seeing 18650 lights that are so big they should’ve used 26650. Of course there are exceptions to this. Overall a 18650 with 3400 mAh is a great size to energy ratio for a rechargeable.
EG
18650 volume - 16.5cc
Max battery capacity 3400
206mAh per cubic centimeter
26650 volume - 34.5cc
Max battery capacity 5200
150mAh per cubic centimeter
The 18650 has great energy density. This advantage is offset when battery carriers are used because the space between them just becomes air and is wasted. Still, it represents a great size to energy balance that the 26650 doesn’t yet offer.
I acknowledge there are many more uses for multiple batteries etc and I’m strictly just comparing 1 cell.
The 18650 might have better energy density than any current 26650. BUT, if you look at the energy that a 5200mAH 26650 can provide, you can’t get it from 18650s without having to resort to a MUCH more awkward package (like side by side). Furthermore, since the 26650 has a lower energy density, it has room to grow. With current technology, you’re not likely to see much better from 18650s.
As far as ergonomics, one of the nice things about 26650 lights is that they have that REALLY nice feel in your hands like a C cell Mag. They just feel right. 18650 lights are skinnier, which might make them more pocketable. But a 26650 light just fits better in the hand. And, of course, lights with multiple 26650s in a battery holder go the opposite direction - they are too fat.
Just because 18650s are the best that doesn’t automatically mean it has reached the absolute best and innovation/improvement will cease or even slow down. 18650s are used in EVs (Prius, Tesla cars, Leaf etc.) and laptop batteries - this amount of demand is only going to increase and therefore 18650s will most definitely improve in the future and at a rate faster than 26650s.
That being said, I agree that the width of a 26650 is nicer than a single 18650 but I also much prefer triple or quad 18650s more like the SRK or TN30/31/32/35.
Keep in mind that I said with current technology. NOT that it can’t happen, won’t happen, or shouldn’t happen. It’s just going to take something new to get past the current slump. I mean, the best Panasonic can do these days is 3600mAH. And the real capacity is only about 100mAH better than the 3400mAH cells. I’m guessing there’s probably a good reason they didn’t just bump it up to 3800-4000mAH. Again, not saying you won’t ever see anything higher. I just don’t think it will be done using conventional ICR cells.
Depends on what you use a light for. EDC, I like cr123/16340 or a single 14500. But I will carry 18650 too, and even a single 26650 triple, depending on pants.
A 4 x AA is not going to be as easily pocketed but can be bright as Ive found with the D40A but less than 4x is weak IMO. Id prefer a pocketable 16340 if Im going to compromise light.
Many 14500 flashlights are taller/bigger than small 18650.
It’s about preference so can not say you’re less flashoholic than others, unless you only have 1 flashlight
I have lights in about every battery size from button cell and CR2 to NiMH C and D cell size except for 26650. I will almost certainly end up with a 26650 light but have not seen the right one yet and wide availability of lights using this size is still relatively new. A new favorite for me is the two parallel cell Small Sun ZY-T08 customized by Mountain Electronics. Fits well in the hand and just feels good with the flat sided battery compartment and back flare for the switch.
Considering that you can get 18650 lights with battery compartments that hold 2 3 and 4 cells in parallel as well as single cell and 2 or 3 cells in series battery holders or a six battery series/parallel setup it seems to me that the OP has a somewhat not understandable personal prejudice. But that is part of human nature.
After battery fit problems with two major brand flashlights that use 18650 battery holders to hold three cells I am avoiding such lights in the future. No problems though with the Fenix 4 cell holder for the TK 75. In fact my biggest complaint about 18650 batteries, particularly protected ones, is that they vary too much in both diameter and overall length which leads to the earlier noted fit problems. The same fit problems exist with 16340 protected batteries and some CR123 lights. In fact I would like to see protected batteries have their own size numbers which reflect the actual dimensions of the finished battery.
Although I do have some 18650 lights, I much prefer much smaller lights for normal use. The smallest 18650 lights are not so small that I want to carry them in my pockets. My favorite is a Tank 007 e09. I almost never use the larger lights, and if I do need more power or time of use I prefer AA or CR 123.
There are a couple lights with 3 26650's in parallel. Okay, maybe it's literally two. It's much better in series though. Most of the big lights with 3 or more cells in series have battery tubes big enough for 26650's, or even 32650's. With those long lights, the thicker battery tube really makes sense.
I have seen photos and read the descriptions of some of the budget three and even four 26650 batteries in series lights with 12 and 15 LEDs and per the tests outputs of 7000+ Lumens or so genuine. The lights are large and bulky enough to be impractical so far as I can see and for any normal use who needs 7000 Lumens other than for wow factor. Also the heads reportedly get hot very rapidly and the UIs suck. I already have RMM Modified SRK and SupFire M6 lights that can put out 4000+ Lumens but find that I typically use them at MUCH lower settings. Fortunately the modified lights have seven output levels available from moonlight to max.
