Hello everyone,
I have a 18V lion 3.0Ahbattery from makita that won’t charge.
Is it possible to try to revice it using my accucel6?
Thank you for the advice.
Hello everyone,
It has a protection/charge management board in the pack as well as the charge management circuitry in the charger. It could be a bad cell or popped spot weld or a bad board. I wouldn’t reccomend simply replacing a cell since it would not be matched but a spot weld could be fixed. You would have to check the condition of the out of circuit cell before reconnecting. A bad board needs a new pack anyway unless you can swap one from a pack with bad cells.
The new gen packs are 4Ahr and they are discounting the older 3Ahr packs now.
Thank you for the reply
How would you test a protection circuit ?
First with a visual check to see if any components look burned then by disconnecting it and checking the cells. Process of elimination. If the cells are good then the pct isn’t.
I know of a trick to reset the protection circuit on single cells, but I’m not sure if it would work or be overly dangerous on a pack like this?
let’s just say proceed with extreme caution with the special procedure to reset a protective circuit.
but it is safe with single cells, and maybe safe with a pack ??
I had a little used pack that the Makita service center replaced for me due to a known problem with one of the cells in the pack being drained by their battery management circuit in the pack. They can check usage, mine had less than a half dozen charges. Now I try to rotate them and recharge at least every few months.
yes they can check cycles even on old NiMh packs, and here warranty relies on time but mainly on charge/discharge cycles . So rotating it’s a good habit.
stop putting it in the charger!
open it up and look for a/pr of low cells.the board runs on just one cell or pair and runs them low.if you boost charge it/them it will work again if you havnt reached 3 strikes with the charger.then you want to use a hobby charger as the controller is bricked.
its a stupid design and a well known flaw.
worst case is you run the pack down and put it away a few months.this allows the controller to overdischarge the cell/pair that runs it.
