What e1000 said.
If you want to eek out every bit of intensity/brightness from normal single 18650 non fet driver light that has a wide forward voltage light [say up to 8.4v] you can use 2 x 18350,s . Turbo brightness/intensity will stay more linear[and higher] right through until they need to be charged. Even the best single 18650 high drain will have less brightness on the second turbo blast and will be less every time turbo is used.
Sure 2 x 18350 wont have as much runtime but you will have higher initial and max linear brightness at all times.
As an example my olight m2x ut [mod xpg2 300000 plus cd] has only 75 percent lumens/intensity at 3.9 volts or under [loss of 75000 candela in this case] on a single high drain 18650. On a little thrower like this i much prefer every available lumen and sacrifice runtime.
