How much power do I lose if I choose the 219 instead of the 519A? Considering only beam quality and usage at distances up to 70 meters, is the switch worth it? Is the 219 offered by Convoy the B version?
While I’m at it, let me ask: I have this Nichia 519A running on a 3V 5A linear driver—would I gain much by switching to a buck driver, or is it not worth the trouble?
On the lower end, not too much.
What is your expectation in the usage of the word “gain”? runtime? brightness?
Reduction in temperature and increased longevity of flashlight components, such as the battery and LED.
I really like the 219b in 14500 sized lights. Its a little underpowered for a single LED in a 18650/21700 light though. Something like a skilhunt m150 with a 219b is great
i assume you’re talking about the 4500K 219"b". it ceased production a year+ ago, so they might be quite difficult to find now.
you likely wouldn’t notice much swapping from a linear driver to a buck driver in this situation, but i could be wrong. swapping a driver is pretty quick & easy, though, especially on an S2+, or anything that uses a brass pill.
A few upsides to the Nichia 519a besides the obvious ones … is the ability to so easily de-done them . Also there are more choices available from 5700k to 2700k .
For me the most obvious answer is to add a minus green filter to increase the CRI and make the tint shift down below the BBL . Giving you a better looking tint without having to change emitters .
If you want I’d be happy to send you some small samples of minus green filter. Just Pm me .
yes! filters. i always forget about filters, but they’re a quick/cheap/easy way to customize or fix a tint. i got some filters from Boaz last year(?) he’s a cool guy.
Depends entirely on your preference. If you happen to like a blue/pink-tinged light, it’s great. If you prefer objective color accuracy, you’ll hate the 219B.
I’ve heard plenty about the 219B, gave it a try, and it ended up being my least-favorite R9080 emitter–the blue/pink overwhelms the true color of objects.
