i was trying some leds with this driver TR-0124B and everything was ok until i accidentally reversed the input to the driver well the driver got hot in less than a second and the voltage sense resistors under the inductor coil split into 2 peaces and now the driver is not working at all well i tried and soldered this ” Trimpot”:https://www.fasttech.com/p/1224400 now it worked again with all its 5 mods the problem is the current is very very low well the high is about 20 mA even i have played with Potentiometer of the Trimpots still same very low current, so is my driver died or it can be fixed ? and btw all the other components on the driver looks ok from outside ofc i dont know what happened for it from inside
here is a pic for my driver and i marked the broken resistor
R050 is 0.05 ohms, I never saw trim pots with such low resistance, trimpot you soldered has 200 times higher resistance…
10 ohms / 0.05 ohms = 200
P.S. 0.05 ahms is almost 0ohms so you can just put a solder blob over/instead of that resistor but if you make that mistake of reversing polarity again you will see some serious damage.
I think the driver will probably be fine once you get the correct value resistor, like stated that POT isn’t capable of going that low.
If you don’t have any spares on hand perhaps you can find one on something you can remove in your spare parts drawer. R050 is pretty common, it doesn’t have to be that exact size, you can use a smaller one as long as the resistance is the same.
i tried a bridge with a wire it worked with one cell but with 2 cells the led fried right away so a resistor must be added , well the resistor was in the driver was R050 i used this site to calculate what R050 means i found it .05 ohm went to many shops and didnt find it, the lowest one i found was .1 ohm and then with this site i found that 2x .1 ohm resistors in Parallel would give me .05 ohm .testing in progress
