I thought this charger was supposed to charge outside bays at 1A and inside ones at 0.5A???
This was supposed to be an upgrade to my D4 because of faster charging, but if the middle reading is correct, it’s charging at 0.4A per bay……grrrrrrrrrrr………
It has a total charger current of 2A available, it can either be used as 2x1A for the outside bays or 4x0.5A for all bays.
If the usb voltage is a bit low it will reduce current.
Well that is solved USB 2 can only output 2.4 amps @ 5 volts so you wouldn’t have enough power to charge all cells at 1amp. You would need a mains connection.
Edit. That is weird because it should have enough power to supply 2 cells at 1amp but only just.
I am sure its fine. Its just a possibility. But there is no way Xtar would sell a charger that isn’t capable of providing the charging capabilities they stated. Any ways the Input parameters are 5v @ 2.1 amps. So you have enough power going in.
