Has anyone seen this article on new rapid charge batteries? Interesting stuff.
I’ve seen this material before, and it is really exciting technology. The main reason being that it is much more chemically stable than current lithium ion, and much more conductive in terms of ion intercalation during charging.
The main problem with lithium ion is that why it may release ions quite well during discharge, intercalation of lithium-ions during charging is a much harder process above 60-70% charge, because there is much less surface area?(don’t know what it means in English, so tried my best) for the ions to deposit in the positive electrode, and a higher chance of rapid heat production and accelerated chemical degradation.
This is why tech like Quick Charge, Dash Charge, and USB-C power delivery all charge extremely quickly phones up to about 70%, but then slow down dramatically. It has to be, since otherwise, the cell would sustain a lot of damage.
Niobium tungsten oxide solves this problem since it forms a super structure when it oxidizes at low temperatures, which we currently live in. This allows for almost no resistance in almost all of the charging process, resulting in cells that could be charged in 30 mins with current charging technology, or even faster with higher power. It’s also extremely chemically stable, meaning it’s extremely hard to make it catch on fire, even if you want it to.
To be commercialized though, it is going to take about 5-7 years.
This is a great development in power storage technology. According to the article not much is needed to change in the manufacturing process and it should be cheaper if not the same cost. The structures also prevent dendrite formations if I read it correctly which will increase the lifespan of a cell and as you pointed out prevent internal shorts/fire. This really is a great time to be a flashaholic! :sunglasses:
“… it should be cheaper if not the same cost.”
Wish this were true for us buyers, but imagine that it will only be true for manufacturers.
… is because, at that point on average, charging circuitry output voltage reachs maximum allowed cell voltage (constant voltage phase begins).
Charging a li-ion cell completely at full speed is possible, but needs precise cell voltage monitoring right at the battery terminals and logic to real time determine cell internal resistance and apply this dV = I × Rcell offset compensation to precisely determine final cell voltage at the terminals at end of charge.
Real time cell internal resistance determination can be easily accomplished by simultaneously charging at two different rates shared at equal time intervals, for example.
And oh well, the whole charging at full speed thing can also be accomplished by briefly stopping and measuring no-load cell voltage at time intervals.
