Is Solarforce quality sub-par these days?
I know many have touted the virtues of Solarforce in the past. But is the reality that they are somewhat more flaky than some of the other budget light makers?
You regularly see Solarforce p60 drop-ins slated for their performance and durability.
The Z1 and Z2 seem to have taken a lot of flack with becoming faulty. Not to mention the whole fiasco with the Z1 not supporting Li-ion, despite being printed on the side of the body that they run at 4.2v.
Then their is the T1. An often forgotten 18650 light, which in a way is a shame as design wise it’s one of the better ones I’ve owned. But yesterday someone reported theirs failing and mine, which I only got 2-3 months ago has been a flickery SOB for most of the time.
My L2M is also the only light I’ve owned (out of many) where the switch has unscrewed itself and basically fallen out, only have the torch assembled prevented this, but it stopped working until I reassembled it.
Sure the machining is nice on all of them. But with a sketchy track record, would you want to invest in one of their pricier models?
This is a question I keep asking myself. I want a K3 and maybe a couple of others. But would they only bring disappointment in the reliability stakes?
I cant fault my s2200. I dont use it a lot though.
Just received a brand new L2N and a head with SS bezel. As usual, all went well and shipping was fast. No problems so far.
The problem of loosening switches is also very common to a lot pricier brands, for example Fenix. Nearly all of them need maintenance of the tailcap (fastening the switch retaining ring) from time to time. Especially tricky, because the threads are fastened counter clockwise… :wink:
I've never been impressed with them. They took over the P-60, but I found flaws in most of their stuff, from rough threads, to out of round bodies, to poor/sloppy fit and dead switches. I don't think they are any better than any other Mfg and it's just hit or miss with what you get.
Guess I’ve been lucky my only issue has been the clicky switch coming loose, snap-ring pliers and a drop of blue Loc-Tite solved that problem. Otherwise I’ve had no complaints about threading or construction quality. I will say that I have NOT tried any SolarForce drop-ins so I have no point of comparison w/ other P60 drop-ins.
I haven’t ordered any flashlights as such recently but I did order an L2-CL1 close up / flood lens that replaces the reflector and gives a good flood beam.
That was flawless.
The P60 drop-ins that Solarforce sell are built well, at least the ones that I have have never failed, that’s not to say they can’t be bettered - they can. The torch gets a look over every time I change batteries and I’ve not noticed any tail switch issues.
I have 9 at the moment and the parts to build another when my international outdoor drop-in arrives. The threads on a couple of the body tubes were a bit gritty but a good clean and some silicone grease and they are smooth now.
I very recently received a head and body for a L2T and found them to be very very good. I had a tailcap (at hand) and it matches the body in the appearance of the anodizing. The head is a shinier black anodize however because I ordered the two parts separately I can’t really complain about that. Had I paid more attention when I ordered I would have noticed the shiney coating.
Basically I’m very happy with their products (an earlier L2N and the current L2T).
I also have an ultrafire wf-502b and the solarforce models are certainly better considering the switches and threading. The switch in the ultrafire did not last very long despite using moderately powered modules.
John.
All of the hosts I've received from them (all for personal use) have been very nice. I haven't used any of their drop-ins, so I can't comment on those.
