I found this one on KD:
http://kaidomain.com/S026866-KZ-3016-Individual-Triple-LED-20mm-1_5A-2_7V-4_5V-Driver-Circuit-Board
Is there an equivalent on the market which delivers 2 modes per LED?
I want t omod a S2+ with 3 different colors and want a low and a high mode for each color.
Cheers
That one can have each LED either on or off. Sounds like two modes to me. :smiley:
You might not be able to use that driver without some mods anyway. Different colored LEDs take different voltages.
Haha, got me :smiley:
Umm, im not that modding pro… hope i mustnt change the driver =(
In the german TLF a guy modded his Convoy with that driver and took a red, a blue and a nichia LED. He didnt mention that he has to change the driver.
If it worked for them, it worked for them.
Either way, it doesn’t have the UI you want.
Thats correct… but if there is nothing on the market i have to take this one.
Thanks for your help!
@milli111, ask Kaidomain to put different modes on the driver of the light.
They accept customization options.
http://kaidomain.com/I3N-20mm-3V-9V-1_5A-1-cell-or-2-cells-6-Mode-3-Individual-Channel-Driver-Circuit-Board?search=I3
That’s the driver they use for their triple color XP-E2 dropin, but it’s the wrong size for a Convoy S2. The S2 uses a 17mm driver.
The inner diameter of the S2+ tube is almost 20.8 mm. If you find a way to attach the driver to the pill it is doable.
So this will illuminate all three emitters? Not just #1 or #2 or #3?
@ggf31416 this one sounds interesting! Thanks for the link.
And this one controls every single LED after the other? So i would have red high, red low, green high, green low, blue high, blue low for example? That would be nice.
Like TBone said, i think the 20 mm should fit.
The “”Sharp Eagle” aka nut light
zoomie reviewed here a few years ago acted like that.
Cycled through high/low using individual cool, warm, and blue emitters.
I’d hoped for a 1, 2, or 3-emitter driver but no.
I found the review of the drop-in that uses that driver.
FYI beyond of the driver only and P60 drop-in format they also offer the PCB with the leds and optics as well as the drop-in bundled with their E6 P60 host.
I checked this one out, but i would like the Convoy S2+ host because of its smaller size and the possibility to use the short tube.
Thanks a lot anyway!
This PCB is used for S2+ triples.
The optics included is compatible to Carclo 105xx. 20 mm diameter but shorter than the original reflector. You will need a (D20*6 mm) spacer on the pill that will give you the D20 mm surface for the PCB. (Example)
