is this NICHIA 5mm new 36.5 lumen
is this a new led 36.5 lumen's from a 5mm http://www.zexstar.com/leduri/leduri-de-5mm/p964/led-5mm-nichia-nsdw570gs-36.5lm-120-alb/
I only see a description for 20 lumen - what am I missing?
16.5 lumens.........sorry, couldnt resist!!
I walked RIGHT into that one...... :)
maybe it can handle more than 50ma?
I have a thing for little tiny lights that use 5mm leds. Whether in the brim of a hat, in the head of a lighter, or whatever...
I'd go nuts on my collection of that junk if I could find a bunch of really good emitters. It has been awhile since I read the CPF thread on testing all that was available, but don't they top out at like 6 lumen?
Producatorul acestui produs. Vezi dictionarul de producatori pentru detalii.
Producator Nichia Japonia
Culoare Alb
In termeni simpli, temperatura de culoare arata inclinatia spre albastru sau rosu a luminii albe.
Exemple:
Lumanare: 1800K
Bec (lumina alb cald): 2800K
Spot halogen(lumina alb cald): 3400K
LED alb cald: aprox 3500K
Lumina solara (alb natural): 5500-6500K
Tub fluorescent(alb rece): 6000-8000K
In cazul LEDurilor temperatura de culoare nu este aceeasi de la un lot la altul. LEDurile din oferta noastra pot avea temperatura de culoare din intervalul de productie. Pentru valori speciale ale temperaturii de culoare este necesara o comanda speciala de la furnizor iar cu cat intervalul dorit este mai strans cu atat costul va fi mai mare.
Temperatura de culoare (medie) 5000 k
Lumenul este fluxul luminos emis pe un steradian de un punct luminos ce are intensitatea de o candela (1 cd). Altfel spus 1 candela va produce 1 lumen pe o suprafata de 1 m2 la o distanta de 1 metru. Un lumen pe metru patrat inseamna un lux.
Exemple:
LEDuri 5mm/superflux: 5lm(max)
LED Luxeon Rebel alb: 180lm
LED Seoul P4: 240: lm
Crop de iluminat cu LEDuri 600x600m: 5400lm
Bec incandescenta 60W: 700lm
Bec incandescnta 40W: 410lm
Bec incandescenta 100W: 1200lm
Neon 30W: 1600lm
Toti producatorii comunica fluxul luminos sub forma de interval (min, max tipic). LEDurile din oferta noastra pot avea, de la lot la lot, orice valoare a fluxului luminos din intervalul sau selectia respectiva (bin). O selectie speciala dupa flux luminos se poate realiza pe baza de comanda de la furnizor.
Flux Luminos (mediu) 36.5 lm
Exemple:
Neon 30W: 1600lm
Flux Luminos (interval) 27-40lm lm
Lumen/watt
Aceasta valoare arata cati lumen se produc pe un watt de putere.
Aceasta valoare este un indicator al eficientei sursei de iluminat. Cel mai ineficient este becul cu incandescenta. In 2007 prin aparitia ultimei generatii de la Seoul Semiconductor si Lumileds, LEDul a devenit cea mai eficienta sursa de iluminat.
Exemple:
LED Seoul P4 sau CREE XRE: 94 lm/W
LEDuri 5mm/superflux: 40lm/W(max)
Bec incandescenta 60W: 11lm/W
Tub fluorescent: 60lm/W
Eficienta Luminoasa 151 lm/W
Unghiul de vedere determina raza fascicolului luminos al sursei de iluminat. Un unghi de 30 de grade inseamna ca lumina are forma unui con ai caror margini pornesc din centru la un unghi de 15 grade.
Modificarea unghiului de vedere afecteaza intensitatea luminoasa (mcd), dar nu si fluxul luminos al unui LED.
Un unghi sub 70 de grade inseamna lumina focalizata, peste 70 de grade lumina difuza.
Unghi de vedere 120 deg
Numarul de volti necesari pentru ca un LED sau produs cu LEDuri sa functioneze corect.Depasirea voltajului recomandant va distruge LEDul. Atentie LEDurile sunt component care depind de curent, nu de voltaj. La un voltaj fix (3.5V) un LED de putere mare poate consuma 400mA la pornire si peste 1000mA dupa un timp de functionare. LEDurile isi cresc curentul de functionare pe masura ce se incalzesc. O alimentare fara limitare de curent (sursa de curent constant) poate distruge LEDul.
LEDurile sunt sortate de producator dupa curent si nu dupa voltaj. Un LED din lotul 1 poate consuma 500mA la 3.5V iar altul 200mA.
Tensiune recomandata 3.4 V
Tensiune alimentare (interval) 3.2-3.5 Min-max V
Numarul de miliamperi (mA) sau ampere (A= 1000mA) necesari pentru o functionare in parametri a LEDului. LEDurile normale necesita intre 15 si 20mA iar cele de putere mare intre 350mA si 1500mA. Alimentarea unui LED la valori apropiate de cele maxime precizate de producator trebuie facuta cu mare atentie. Un LED solicitat la maxim produce mult mai multa caldura care trebuie disipata efficient. Nelimitarea curentului sau lipsa unei raciri adecvate va distruge LEDul.
Curent recomandat 36 mA
Curent (interval) 27.0-40.0 mA
Cantitatea totala de energie consumata de un LED sau produs cu LEDuri. Ea se obtine prin imultirea tensiune X curent ( 5V X 1A= 5 Watt). Numarul de Watt nu are nici o legatura cu performanta unui LED. Un LED de 3W de la producatorul de la Seoul, Cree sau Lumileds (eficienta min 80 lm/W) este mult mai performant decat un LED de 7W produs in China (eficienta 30lm/W).
Consum 0.28 W
Lentilele pot fi clare, alb difuze sau colorate in masa. Majoritatea LEDurilor au lentil clare care nu afecteaza culoarea sau fluxul luminos.
Tipul de lentila Claritatea apei (lumina focalizata)
Garantia produselor oferita de firma noastra. Vezi sectiunea despre garantie pentru detalii.
Garantie
3.5V (max) * 0.040A (max) = 0.14W, not 0.28
at 151 lm/W, 0.14W = 21 lumens
and it’s quite suspicious that the lumen and current ratings are identical.
Update: Found Nichia’s data sheet (www.leds.de/out/media/15031.pdf)
Max rating is 80mA at 3.7V; the 36.5 lumen rating is the top end of the highest available flux bin (min. 30.5 lumens) at 70mA.
Hmm after looking at these further I wouldnt mind having a few to play with. Question is where to get thats ships to the US?
30 lumen at 70mA ?
So a one-amp driver could power ~14 of these for between 420 and 500 lumen ?
Holy floody output, Batman ! A one-cell light and a 2.8A driver with 1200-1400 lumen?
Wow. Time to break out the showerheads.
Shower head indeed.
That 109 LED flashlight would be ridiculous if loaded with these (109 x 36.5 =3978.5 ) Umm, how much are these Nichia LED's going for anyway?
I'd love to know too, I'd guess the lumen/$ is much lower than xml - and they'll only be economical for small projects...
http://www.led-tech.de/en/Light-Emitting-Diodes/Superflux-LEDs/Super-Flux-LED--1-Chip-Technic--LT-1533_1_7.html
wish these bastards were cheaper
Something like 1.80ish per superflux led.
I need 2 or 3 tubes of them right now.
Need to locate a place in the states that has them.
At that rate there will be no super shower head anytime soon.
Might be a good update for a solitaire or similar.
I think there are some new super strong 5mm LEDs about already and I think I've got one by chance.
I received another 10 pack of keychain lights this week, this batch from KD. One of the lights is AMAZING. Unlike any I have had before. It throws a hard edged crisp beam with visible hotspot and spill. Its obviously not as strong as a P60 XPG with OP reflector but the beam profile is similar as regards beam edge and hotspot definition. You would think it was thrown from a reflector not just a 5mm LED. The beam has a cold (blue to purple) tint hotspot transitioning to a markedly warm spill.
What is most surprising is that it is to the eye many times brighter than any normal keychain light and also to the eye nearly half as bright as a Black Cat when both are at 2m. I have no way of measuring lumens but comparing it to lights I have which I know the approx output of I'd say its damn close to or possible over 20lm.
BTW this was the only one like it in the 10 pack and literally made me gasp when I first tested it.
