Is this Noctigon still usable? (Damaged)
Hi guys, do you think this Noctigon is still usable? I damaged it when prying it out of my light.
Looks terminal. Test it with a DMM. But why fool around with it? It would be a shame to invest a lot of time and effort into a build only to have a relatively inexpensive ($1.99 at RMM) component fail.
I don’t understand. What happened? Why is there solder on the wire pads but not the emitter pads?
Looks like there are some small smudges on the led pad, maybe from a failed reflow. Another reflow would probably not work due to the gouges through the pad.
Check for shorts between any of the pads and the copper base.
You should post a warning label.
Gruesome image images ahead, open at your own discretion. :slight_smile:
(If I was impatient and didn’t have another, I would test for shorts and opens and give it a try.)
Outside the light of course, You don’t want to have to pry that sucker out a second time.
Glad you’re not my dentist (jk)
Phil
It’s still usable for sure… As a spacer :stuck_out_tongue:
I’d forget about using it as a circuit board and file/sand the rest of the face and have yourself a nice 1.5mm copper shim. :smiley:
Cheers
Have we learned to avoid thermal epoxy?
I haven’t, but then again I use heat when it comes time to take it off, and it’s always been pretty easy for me.
looks usable to me. might need some polishing but it’s gonna be okay
I use thermal mustard.
The DTP mcpcb is what actually makes a difference imho.
Looks ok to me, none of the pad gouges seem to go through the dielectric layer. I’d sand it to remove the ridges under the led and cover the scrape between led- and “Noctogon” with AA or Fujik and let er rip. Testing is a good idea.
Thanks for your input guys. The smudge on the center pad is definitely from a failed reflow. I bought a DOA SK98 and when I went to remove the glued down MCPCB, my hand slipped and the LED popped off and went flying through the air, lol.
I know it’s probably not worth it to try to use it again…I just wanted to check with you guys before I threw it away. Thanks again.
