Is this Vapcell S4+ v2's "normal" behavior when testing Li-Ion battery capacity?
So I bought my charger a week ago and noticed that it doesn’t want to Cap.-test at 1000mA (I’m aware that only CH1 and CH4 support this discharge current rate)… Sometimes it does work, but most of the time it only discharges at 500mA no matter what current rate I select. However, if I choose “Discharge” it works as intended… Is this common? Can I confidently use the Discharge function to do capacity tests at 1000mA?
Are using Auto or Manual mode? (the small switch on the right side)
If Manual, are you choosing the charge current to be 1A or above?
If you set to 1A for cap-test then both charge and discharge should be 1A. If 2A then it’s 2A charge, 1A discharge (slots 1 & 4). If you choose 500mA then it’ll be 500mA charge and discharge.
If you’re using Auto mode then I’m not sure because I’ve never used Auto for a cap test.
Welcome to the forum.
I would assume that if you manually charge the cell before hand, then yes this would give you the measured energy of the cell when discharged at 1000ma.
The cap test setting does a charge, discharge, charge cycle automatically for you so is more convenient.
I’m using Manual mode, forgot to mention it… I’m trying to replicate the behavior that I’m experiencing by testing with batteries of different capacities and internal resistance. If I arrive at a consistent conclusion I’ll share here, otherwise, I’ll use the discharge function to do capacity tests 'cause I don’t want to go through the hassle of returning it ( bought it on illumn.com for $26.99, BTW)
Thanks! I’ve been reading occasionally for a while but today I decided to post!
So far I’ve found out that cells with fairly low internal resistance always discharge at ~1000mA if I select a current of 1500mA in Cap. test mode. I still need to verify if selecting 1500mA is really necessary by testing with other cells.
I hope you have fun here, samthelion17!
The number won’t be accurate if the cells get too warm and that would defeat the point. Plus you could damage the electronics if you tried it on the two center channels, so they’re limited to 500mA discharge no matter what, in any mode. Only the two outer channels are ever capable of 1000mAh discharge because while the outer slots have these…
…two little heatsinks between them that maybe do a fraction of something resembling cooling, but not much with no air movement. And the two center slots send all the heat to these little guys…
and they’re just floating there nekkid!
For real, when I tried capacity testing 4 cells at once in my S4 it got so hot that the thermal grease melted off of the temperature sensors. You don’t want to capacity test at 1A. Too much heat for this charger
I’m not an expert, but not sure how this would happen, surely thermal grease rated for +90C given CPUs can reach this temperature?
I will agree that ther thermal grease can “escape” though, mine weeps a tiny amount from around the temp sensors
You would think right? Melted might not be the right term but it’s an accurate description. The tops of the sensors were clean and shiny. If that was pump-out it was pretty severe pump-out.
Didn’t hurt anything. I just cleaned it up and put some more on.
The stuff on the backs of the two FETs stayed in place fine
Nice photos! now I don’t have to disassemble mine to see what’s inside. So, normally I wouldn’t need to test batteries at more than 500mA but sometimes I want to be certain that a cell can withstand a heavy load, so I run a cap. test at 1A. Also, I like to keep an eye on the temperature and thus far I’ve never seen a cell over 45° C.
That’s not too bad. 1 cell isn’t too bad, even two. 1A isn’t really a heavy load, but you do get an idea from the temperature and voltage drop. Electronic loads are expensive. I’ve been meaning to get one.
You can make something if you’re careful. You can get a bunch of power resistors off AliExpress for a few bucks. They don’t tell you that a 100W resistor can’t actually disappate 100W without an appropriate sized heatsink. Figured that one out pretty quick lol
I was just about to post a new thread called “S4 +V2 common behavior”. I’m glad i came across this…
I too have noticed odd behaviour & it has had me scratching my head, as well as concerned on a free occasions.
So this charger is brand new. I purchased it along with a new batch of Molicel M35a’s.
I’ve always gotten by for the past 15 years with a janky a$$ 2 bay ultrafire 139, so this S4 + is a Cadillac in my eyes.
After messing around with it on some calls i don’t care about i tried it out on the brand new Molicels.
Here’s where things got odd. After charging, I tried the 1A discharge function in one of the outer bays as i didn’t feel like waiting on a Cap Test. The battery got pretty dang hot (at least it seemed hot to me), like 57c°. I never feel my cells get that hot, not even in poorly designed lights. I eventually pulled it out due to concern i was going to damage the new cell.
The next day I decide to mess around again & I tried to charge 2 cells @ 1A. Unfortunately, I ended up with the same result. Things got really hot, the cells were around that same 55c°-60c° mark, but the charger itself felt even hotter.
At above 0.5A, the same thing seems to be happening no matter what function I select, charge, discharge or cap, it dont matter… It also seems especially hot with these Molicels. With that said, when i run dicharge or cap in the the 0.5A bays, everything seems fine.
Like I mentioned before, Ive never experienced heat like this in the junky ultrafire charger nor in any of my abused cells when running them in lights pulling much more than a 1 amp.
I’ve also experienced what seems like odd behaviour… I’m not sure how to explain it… like, cells I know are charged reading at 50% & other data readings not looking “normal” for where the cell should be at.
Could the charger be faulty?
Are these M35a’s not what their cracked up to be?
I’m not sure how to digest this ongoing scenario.
The heat is not coming from the cells, it’s coming from the charger. To discharge the cells, the charger turns the energy into heat. The electrical components that do that are in the top of the charger and the heat gets into the cells and the temperature sensor.
When I do discharge tests I aim a fan at the charger, concentrating on the top. In my case I use an old PC case fan that I hook up to my variable bench power supply and just sit it on top of the charger over the cells. I don’t even run the fan at the full 12V speed; 6V is plenty fast to keeps things cool.
Edit: Looks I failed to read your whole post. I assumed you were only getting the really high temps on discharge (or cap test). If you’re only doing a charge (and no discharge/cap test in the other slots) then you should not really be seeing anything above mid 30s-C at 1A charge.
Only for the outer slots eh
The ones for the inner slots are on the opposite side.
Take a look at my pictures up there. On the outer slots the heat goes into a heat sink, spreads the heat out, makes the whole charger feel warm. That’s what you want.
For the inner slots they aren’t on a heatsink they’re just floating there. So they are getting hot, hotter even than the outer slots are getting, but they dont warm up the rest of them charger. They’re probably red hot they just aren’t warming the charger.
The m35’s arent comparable to the p28’s. They’re fine but they’re just kind of average. They aren’t high drain. But it shouldn’t be getting 55° on a 1amp charge. Something is definitely wrong with those. Getting that hot on discharge is expected, not on charge.
Are you sure you don’t have the charger set to auto and it’s using a 3A charge on those?
I used the Vapcell rarely for my LiIon, but my 18650s with around 2,6-2,9Ah I charged with 1A don´t getting warm and never hot.
Thanks for all of the responses.
Forgive me I’m still trying to figure out how to quote on this platform.
You mentioned something about the bays without heatsinks possibly getting red hot. After feeling how hot the body got, i don’t doubt that possibility. However, with that said, is it normal for chargers to get that hot? Youd think red hot components would liquify the solder joints or cause severe damage, nevermind the fire hazard.
Regarding the M35a’s… It’s a bit fuzzy at this point, but IIRC, it was only one of them that I tried to Cap/Discharge at 1A. Then when Charging the other M35a’s, Ive done so at 0.5A & things didn’t get hot. It has however gotten extremely hot with other cells I have.
My main two things I’m trying to figure out now, are…
  1. Is it the charger getting so hot that its heat soaking the batteries, causing the cells to feel & read way too hot?
  2. Or is it the cell/s causing the temp.
The odd thing here is, the resistance reading & age of the cell doesn’t seem to play a role in whether things get super hot. It all seems to randomly revolve around running the functions over 1a.
Oddly enough, i just charged a hammered 10yr old Protected “AW” cell at 1A & it never peaked past low 30C°s. Again, it all seems so random, hence why I want to think it’s charger related.
To quote text on your reply just select the text you want quoted with your mouse and when you release it the following box will appear, Then click on Quote to begin your reply.
I’m not sure how they made these but I’ve had so many issues other than this discharge. I won’t get into that. In terms of discharge I use my opus. Been working great for almost 7 years.
I could discharge four cells at 1 amp and have never ever had a heat issue. It does have a fan a little fan so that must help.
