Given the relatively same reflector size and dimensions, I’d guess that the beam profile of the E2 would be very similar to the S2. However, the S2 would throw much farther simply because of its brightness.
The E2 Nichia 219 puts out about 300 lumens. The S2+ puts out more than 400 lumens in its lowest available 7135x3 configuration. In the 7135x8 configuration, it puts out around 1000 lumens.
And your title mentions the S2. Are you interested in the S2 or the S2? They are two different models. The S2 is a little larger than the S2. The S2 is slightly throwier than the S2+.
Neither are ever going to be throwers. The reflector is too small.
The S2 should throw slightly better than an S2+ due to the reflector, but you’d probably need them side by side to see the difference.
For more throw you may want to consider a different LED. A smaller LED relative to the reflector size will give you more throw.
I have an XP-G2 Convoy S4 and a Nichia 219B S4. Bought as hosts and running a 3.04A Qlite. They perform very similar to each other, the XP-G2 maybe slightly throwier. Both are IMO nicer lights than most XM-L2 tube lights due to the extra throw they have.
If you want more throw, then something like the Convoy M2 might be worth looking at. Slightly bigger than the tube lights, but still pocket friendly. A well driven XP-G2 in one of these will throw well.
I do own both and can say that you’ll notice the difference. A smooth reflector is a plus but I doubt that XP-L HI will be enough to see a difference in throw. What you want is a dedomed XP-G2 but the tint lotery might be frustrating
Depends how much throw you want. I’ve not gone de-domed XP-G2, as I suspect the spill beam might be too dim and it still won’t really be a thrower.
I have a couple of examples that might help:
S2+ nice and floody
XP-G2 in a S4. More throw, but narrower spill beam and spill beam less bright
And this is an EagleTac D25LC2. This is the old model running the original CW XP-G (not XP-G2…). It throws very well for it’s size and lumen level. Has quite a deep reflector.
