Awesome looking light. I’ve seen a couple of threads on here about it.
I have a question though, is there any way to eliminate the dark cross in the beam centre ?
Or another option, can the LED be changed to amother, but retain the same amount of brightness / throw ( or even more ) without the beam artifact?
The updated model uses an OP reflector which drastically reduces the center cross, I installed it in mine and now its just a small hole in the beam, only visible if you look for it.
I think you can change the LED to an MTG2, but no one has done it yet.
Adjusting reflector height also helps, but you lose some throw.
Oh cool. I thought I saw a pic of 2 side-by-side with SMO reflectors while surfing. Now that I know this piece of info, I’m keen to grab one. Thanks for that.
Would you say it’s a good thrower ? Does it push out to a useable say 350m + ??
Yeah, Ive had just about all the 6v LEDs you could imagine in these X6’s…I just sold a MT-G2 for $200.00 it was that nice! you want to use a XHP70 Frost it…. You want more throw Shave it…. These are one of the best designed and built lights with excellent machining quality. I have one with a pressed in copper heat sink I made, fully potted reflector cavity, Shaved and polished XHP70, pulling 12.2 amps, and can run WOT outside in this weather with out issue. It sheds heat that well, and its a very huge throwy beam that lights up the farm fields like a search light. Everybody I have ever let use these lights are nothing but impressed with them, some have even become BLF members after using them!
If you use the brass pill, lightly solder the threads up and re-cut them using the the head, before building the pill, take your time doing it, you have even better heat transfer! I don’t like using thermal paste on threads. I remove the ano and polish the surface the pill head mates too, often I have spotted this contact point in ,more contact better thermal transfer. Make sure your pill surface is flat and smooth, polished, and your mcpcb board too. I solder bond the mcpcb to the pill, I don’t like thermal paste, if I can help it?
