JETBeam IIIM Ultra 2000 lumens Tactical Flashlight is out now
A High performance Tactical style flashlight from JETBeam, the IIIM Ultra has been released by the company. This updates their extensive range of flashlights with their triple tail switch, for rapid and easy operation. Giving instant access to Strobe, Turbo and SOS modes via the dual paddle switch. This patented design is durable and provides excellent tactile feedback, and in combination with the U shape tail, and central switch (for On/Off and a Momentary mode) – all the controls you need for the flashlight are in easy reach, and ideal for one handed operation.
The CREE XHP35 HD give a high maximum output of a blistering 2000 lumens, and a range of 270 metres. There are 4 power levels, with a long run time of 26 hours at the lowest level of 40 lumens.
Using a high capacity 18650 battery (3500mAh), the IIIM Ultra has a modest size of 142mm x 35.3mm x 26.4mm (5.59” x 1.38” x 1.03”), and a weight of 120g no battery (4.23oz). The design has an attractive angular look, with a black stainless steel bezel, and clip, with a high quality HAIII anodized finish on the aero grade aluminum to resist marks and damage. A type C charging port is on the flashlight, a Red LED battery indicator, and it can also be used as a power bank with the included dual design USB cable which is included.
CREE XHP35 HD for 2000 Lumens Output, and a range of 270 metres
The IIIM Ultra has a range of 4 power levels, the top Turbo mode hits an impressive 2000 lumens with a mixed beam pattern, this gives a good range and spread making it ideal for many uses. Turbo reaches 270 metres, with a high level output of 950 lumens, a medium of 250 lumens and the lowest level is 40 lumens making it suitable for closer subjects or when battery conservation is important.
The 2 Strobe modes are also 950 lumens output a standard strobe for self defense, and an SOS for emergency signalling
Triple Tail Switch Design for Fast and Simple operation
Any tactical style flashlight needs a control layout that is both fast and intuitive. JETBeams latest patented triple switch design features a classic U shape tail, making it easy to located even in darkness. A single central switch turns the flashlight On or Off (with a half press for Momentary), the 2 paddle switches provide access for either side (both paddle switches are a single switch). This lets you quickly access Turbo, Strobe, or SOS modes. A memory function is also present to remember the last power level set.
Single handed operation is a key design for this JETBeam flashlight.
Another useful feature on the JETBeam is the ability to use the flashlight as a power bank
With an output up to 2.4A, it can quickly charge many devices such as a phone quickly. Also included is a dual type charging cable, this features a type A output port in addition to the usual connectors. Allowing you to attach any type A cable to the flashlight to charge it. Of course you can also use type C devices is you wish.
A battery status indicator is on the side near the charging port, not only does this inform you when it is charged (Red is charging turning to Green when completed). When the IIIM Ultra is Off, a quick press on either paddle switch, will flash 1-4 times giving you a visual 4 stage feedback on the level of charge left with a critical level when the red LED is flashing. Charging is also fast, with an input rating up to 1.8A
As expected the usual high quality finish is present here, with the gunmetal grey finish a welcome change to the more usual black, it has high grade aluminum alloy, with type HAIII hard anodizing, as well as a toughened ultra clear mineral glass covering the LED and reflector. IPX8 rating for 2 metres water submersion, it is also impact/drop tested to 1 metre.
JETBeam IIIM Ultra Key Features
  • CREE XHP35 HD LED with a Maximum output of 2000 lumens (270 metres range)
  • Triple Tail Switch with U shaped design, quick one handed access to all the flashlight settings including Momentary, Turbo and 2 Strobe modes
  • Ideal for multiple uses, hunting, law enforcement, camping and search & rescue
  • High Capacity 3500mAh 18650 Battery, compatible with CR123A (16340) cells
  • Maximum runtime up to 26 hours (40lm output mode)
  • Power Bank Function
  • 4 Stage Battery Level Indicator
  • Reverse polarity protection
  • IPX8 Rated to 2 metres water submersion, with 1 metre impact resistance
  • Intelligent temperature control ensures long lifespan of the LED
  • Compact size, 142mm x 35.3mm x 26.4mm and a weight of 120g (no battery)
  • Stainless Steel Bezel and clip with spare O ring, charging cable, lanyard and padded holster
I'd like to hear any thoughts on JETBeam IIIM Ultra
Use IIIM ULTRA get 10% discount now
IIIM ULTRA
Looks good. Specs look pretty good. I have a TH20, Jet-IIM Tac and a few different smaller lights. This and the Acebeam P16 are on my list of future purchases
Looks good, nice job.
It seems that the Jetbeam flashlight is not very popular in BLF, which may be caused by the manufacturer's own non-retail. But I think its quality is good.
Agreed. Jetbeam doesn’t do a lot of advertising to us enthusiast. I keep up with them because I really do like their quality.
What is the strobe frequency?
Strobe: output 950 lumen, runtime 5h
XHP35 is really outdated now. If not using XHP35.2 and or offer warmer tint, this light is not interesting enought.
…and frequency?
I think they are still well thought of. Maybe not as popular since enthusiasts have moved heavily toward fancy UI like Anduril, and compact multi-emitter lights have really taken over lately, as well as high-CRI emitters. I will say that I rarely see Jetbeam’s name in advertising or suggested products…not sure why that is but they have always seemed like a “quiet” company to me (but many companies are like that).
The only Jetbeams I see mentioned a lot are the rotary ones. This one is a tacticool light with no real low mode, so it isn’t really going to be popular here.
Cant tailstand and no firefly or low. I need a light to tailstand as I sometimes use them as lanterns bouncing off ceiling.
This light and the lights like it have done a great job for those of us needing those type to duty/tactical lights. I hate the word tactical to explain a simple flashlight. You want androol or any other bells and whistles there are always plenty of options for those.
These here are my kino of lights.
Strobe frequency: 8~10hz
What is the rated CCT? I read the description above and a few places that sell the light online, but there is no mention of this. Can I assume it is in the 6000 to 6500K range?
You are right, it’s 6500k
