Just sharing my Sipik SK68 mod
Nothing fancy. I just loved this specific SK68 over all SK68 I owned.
I had a few 7880 driver and a spare XML T6 1A so I just dump the badly dedomed stock XPE and replace them here.
not my sexiest solder work here. I’m not too sure why I can do it professionally when I’m lazy but terrible when I’m really into some modding.
will clean it up once i found an old toothbrush
Accidentally cracked the tailcap while trying to wire the switch up. Some hotglue fix this problem
The spring got burnt when I was using it in stock form with a 14500 in the past project. I should consider changing it but I’ve already hotglued it (silly me)
The 7880 driver was just superglued on the pill with some ground wire sticking out the side. I find this method best especially when my soldering is inconsistent.
I just screw the ground wire into the threads and it’ll give good contact with no flickers that way.
Video just shows a demonstration of the 7880 driver modes. If you’re familiar with the driver then there isn’t much to see.
I just love how bright the flood is with this. Most importantly it doesn’t get hot. Just stayed warm enough to keep some hands cold in freezing conditions.
I wanted to put a driver for 14500 but when I think about the heat I gave up that idea. My country is hot enough coming from the sun
haha thanks for the encouragement :smiley:
don’t think it’s the brightest in this world.
I’ve seen people doing the same and running on 14500.
there’s people even adding sst-50 in their sipik as well and they claimed instant heat up lol
example 1
example 2
oh nice!!!
Great mod…love them little flashlights, I too have the problem of the little plastic retaining thingy coming loose on the tailcap…I even peened the leading edge in to hold it only to find out it made the threads a bit “gritty” your hotglue idea might be a cure
Awesome
Silicone would be a better choice as hotglue morphs around in age even when it didn’t get hot but things will get permanent.
I’m still finding a way to remove silicone cleanly as how I remove hotglue with methanol or superglue with acetone.
great mod!
I have a weakness for sk68 mods because I did so many of them. I never carry them around because the sk68 is too big and pointy for pocket carry, but I like them anyway.
yea same here.
I find sipik sk68 just too sexy.
I never find them pointy though. In fact I find the pocket clip being super sturdy for a cheapo
if only we could have a constant high quality sk68 for purchase.
[if only convoy decided to redesign the sk68 ahahaha]
Update:
Had my light run on high non stop
It can last a whole 3 hours on high just on pure alkaleaks (energizer)
sounds like good stuff as compared to my edc light that runs for 1 hour 50 minutes on 14500 stock xpe for roughly the same brightness.
I am pleased~ 0:)
New Update:
Just did some swapping in between different sipik clones
Apparently a hollow pill with screw retaining ring had better heatsinking than a solid pill with no retaining ring.
So I threw my XML T6 to the other hollow sipik with a 3mode aa/14500 driver and the other one with a dedomed unknown xp-e
The dedomed xpe was in the black sk68 and it looked horrible with artifacts and shadows due to the unclean dedome as well as larger lens.
The XML T6 was in the silver one and it didn’t really flood well nor spill well with that smaller lens. It wasn’t really bright with the 7880 driver nor dark enough for moonlight
Now both has swapped its location and things has gotten better
SO MUCH BETTER
Lights were about one foot from the wall.
I didn’t bother bout the flood on the black sk68 with XML because it’s just a spare (I can turn it into a mule anytime)
but the dedomed xpe gives my favorite color tint as well as useful even spill for my midnight trips to the toilet
(still waiting for my xte to arrive… not sure where it went… just ordered a nichia as well but I decided to throw it into a p60)
in the meantime I fixed my tailcap switch with one of these rubber tap washers
works pretty well holding things tight
