Kaidomain - Dual USB charging 3 x 18650 XML
Hey fellas and fella-ettes,
just wondering if anyone has any thoughts or experience with this
http://kaidomain.com/product/details.S020383
I like the concept for taking it hunting with me in the bush on multi-day-week long trips.
The thought would be with a solar set up something like this”
http://www.dealextreme.com/p/4w-660mah-foldable-solar-panel-battery-charger-w-6-x-adapters-137417
I could use it for everything from charging phone and gps through to heavens forbid…. a torch.
I like the idea, but it is nothing that a deep pocket full of 18650’s and a little usb adapter could not do, but would mean extended stays :bigsmile: in the bush would be no concern.
Interested to hear from you all
II’z
Take a look at this: https://budgetlightforum.com/t/-/8298
Its the same flashlight. But charging 3 cells with 660mA.. might take a while. Also, be sure to use good protected cells because there is no low-voltage cutoff when charging external devices. And, ofc, its not waterproof. ;)
wow, that’s so cheap, assuming it is truly the same as the light from intl-outdoor that was reviewed
The name on the side of the light and the back of the driver looks the same as the reviewed version, might be a good deal
