Thank you :)
The dinner was short but i had to do a lot of measurment so i am back only now !
I know that's a lot of numbers but i'm still searching a way to display them in a clear and nice graph (anyone knows how to have several secondary axis on a graph with Libreoffice Calc ?)
At first i measured a led alone, varying the curent and measuring the led voltage and light output and calculating the led efficiency :
Supply curent
(mA)
Supply Voltage (V) Supply Power (mW) Light output (lm) Led Efficiency
(lm/W)
1,0 2,59 2,7 0,3 129
2,0 2,62 5,3 0,7 128
3,0 2,64 7,9 1,0 126
4,1 2,66 10,8 1,3 125
5,0 2,68 13,4 1,6 123
6,0 2,69 16,2 2,0 122
8,0 2,72 21,8 2,6 119
10,0 2,74 27,5 3,2 116
12,0 2,76 33,1 3,8 114
15,0 2,79 42,0 4,6 111
20,0 2,84 56,8 6,0 106
25,0 2,88 72,0 7,3 102
Then i did the same kind of measurements on the driver + led and used the (roughly interpolated) led efficiency calculated in the previous table in order to obtain the driver efficiency :
Supply Voltage (V) Supply curent
(mA)
Supply Power (mW) Light output (lm) Total Efficiency
(lm/W)
Led Efficiency
(lm/W)
Driver Efficiency
0,60 10,1 6,1 0,4 65 128 51
0,70 15,6 10,9 0,7 67 128 52
0,80 22,7 18,2 1,2 69 125 55
0,90 25,5 22,9 1,6 68 122 55
1,00 27,9 27,9 1,9 67 122 55
1,10 29,8 32,7 2,2 66 120 55
1,20 31,4 37,7 2,5 65 119 55
1,30 32,7 42,5 2,7 64 118 54
1,40 33,7 47,1 3,0 64 117 54
1,50 34,8 52,4 3,3 63 116 54
1,60 38,1 60,8 3,8 63 114 55
The efficiency is not too bad for a "wet finger" type of design but the light output is a bit low for my taste.
For comparison here are a few values that i measured on a warm white Sofirn C01 :
(mA)
(lm)
Total Efficiency
(lm/W)
1.0 38 38 3.0 80
1,5 54 81 5,5 68
So now i have two options :
1) Try to optimize the joule thief driver for more output (find a better transistor, test various parameter changes for the transformer)
2) Use a more conventional (and predictable) regulated boost driver
Well it's 03:15 so the only real option right now is to go to bed ...
Edit : corrected a few errors in the driver + led table
2nd edit : C01 data with more accurate test
