I just put together my new light using KD’s 8x7135 driver. It appears I only have HI mode. I remember someone else having this problem but don’t quite remember what the fix was. Any help guys?
Hmmm. I think that is exactly what I have! I wasn’t getting contact from the driver edge to the pill so I had to add a blob of solder. Just my luck I added it right at the ground wire. I’ll have to check it out in the morning.
Shorting led- pad to gnd ring gives direct drive(bypasses 7135’s) shorting led+ pad to input pin of 7135 gives 1-mode current controlled(bypasses micro controller).
Got it fixed! :bigsmile: I just wish I had known the directions for the jumpers for HI-MED-LO and LO-MED-HI were switched. I wanted low first but got hi first using the directions supplied. Hmmm. Got hi first. That didn’t sound right.
Prolly why I didn’t read the directions first too!
I just went and re-read the directions. I thought the O was open and the X connected but the directions say the opposite. That means the directions are right and I was wrong. I guess it pays to read ALL the directions and not just glance at the chart.
Dog gone it! Now I’m having trouble maintaining a good connection from driver to pill. I cant solder the edge to the pill because it’s aluminum. What’s the best way to fix it?
I ordered SOLDER-IT aluminum solder paste - hoping this will do it, waiting for it to arrive. for the light I'm working on, there is a lot of upwards pressure on the driver because of the stiff + and - wires, so soldering to aluminum is my only choice - lack lathe or other press-fit choices. Several attempts have failed - think I ruined 2 drivers.
Well, there is the Nanjg105c and the KD V2 driver.. both have differente mode settings.
Some nice pics of the Nanjg105c:
I read your slightly derailed thread asking about the connections.. you can see most of the traces in these pics. Besides the MCU (Attiny13) and the AMC7135 chips there are only 4 more parts.
The black thing on the right side of the MCU is for reverse polarity protection, the two resistors should be for low-voltage stepdown and I dont know about the brown thing on the backside, but it looks like a capacitor.
indeed a capacitor. I bridge them with a resistor to cut stubid next mode memory out and leave instead a 3 second back to high. I use a 1 megaohm resistor. Or, I eliminate the capacitor alltogether and bridge-solder without the resistor to get one-mode high. I find myself for simplicity’s sake leaning toward the latter these days. Particulary needed on weapon lights. H)
