KD2 extremely dim
Hi' i apologise if this is posted in the wrong place, i'm quite new on this forum.
I got two if these KD2 bikelights, one of them got this problem, i cant tell you how it ended up like this, (maybe it got reverse voltage on input for a short time)
i did some measurement for you to see
it was fed 8v from lab supply.
on the pictures you see voltage going out to LED on low, mid and high mode.
on the last picture the light is on full power, here you can see how dim it is
http://imgur.com/botSQeX
http://imgur.com/Yjkk9Ip
http://imgur.com/NhQ2SXC
http://imgur.com/wMJdrQe
The light:
http://shrani.si/f/2b/Vp/27m8vQ4s/p1040328.jpg
The voltage doesnt matter.
The current through the LED counts for its brightness.
Usually each XML2 LED should draw up to 3A and have around 3.3V
The boost driver needs to feed those LED and then measure current and voltage, of the LEDs are not connected you get wrong readings.
A usual reeding over those LEDs should be 6.5V at currents around 2.2A on highest mode
http://www.kaidomain.com/p/S023801.Circuit-board-for-KD-2-x-Cree-XM-L2-U2-4-10-Mode-Bike-Light
