Keep or not to keep (old Trustfire real batteries)(and laptop batteries)
I have now changed my old batteries with new ones, better ones in many ways. (see the list under).
But I have around 20 old TrustFire (80% blue, rest flamy). The oldest is around 8 years old, the newest maybe 4 year or so.
I have tested them in my BT-C3100 and it’s seems like they hold very good on to their rated mAh (most 2200-2500mah, 4 x 3000 mAh). Most are protected. I have no plans to use them anymore. So keep them, or not to keep them? (Garbage)
Is it any danger storing them in plastic holders for years? They are fully charged now. But with my new list, you can understand why I will not need them anymore.
12 x Samsung ICR18650-26FM 3.7V 2600mAh 18650 – flat top -
16 x Samsung ICR18650-26FM 3.7V 2600mAh 18650 – protected -
8 x Samsung INR18650-25R 3.7V 2500mAh 18650 – 20A – flat top -
8 x Samsung ICR18650-32A 3.7V 3200mAh 18650 – flat top -
8 x Samsung ICR18650-29E 3.7V 2900mAh 18650 – flat top -
4 x Samsung INR18650-30Q 3.7V 3000mAh 18650 – 15A – flat top -
4 x Samsung ICR18650-30B 3.7v 3000mAh 18650 – 6A – flat top -
4 x LG HE4 3.7v 2500mAh 18650 – 20 A
8 x LG MJ1 3.7v 3500mAh 18650 - 10 A
37 x Panasonic NCR18650BE 3.7V 3200mAh 18650 – flat top -
37 x Panasonic NCR18650BE 3.7V 3200mAh 18650 – protected
8 x Panasonic NCR18650PF 3.7V 2900mAh 18650 – 10 A flat top -
6 x Panasoinic NCR18650B 3.7V 3400mAh
50 x Sanyo UR18650ZY 3.7v 2600mah 18650 – flat top -
12 x Sanyo NCR18650GA 3.6V 3500mah 18650 – 10A – flat top -
2 x Sanyo NCR18650BF 3.7V 3400mAh 18650 – 6.8A – flat top -
2 x Hmeng IMR18650 3.7V 2250mAh 18650 – 40 A -
2 x Hmeng IMR18650 3.7V 2600mAh 18650 – 42 A -
6 x Hmeng IMR18650 3.7V 3000mAh 18650 – 45 A
7 x Hmeng IMR18650 3.7V 3500mAh 18650 – 60 A -
2 x Hmeng IMR26650 3.7V 3500mAh 26650 – 40 A -
2 x Hmeng IMR18350 800mAh 18350 – -
I have plans to start selling some of the batteries, so I will not keep so high number for my self. But until some are sold, this is my inventory.
So keep the old one, or trow them away? There can’t be a marked for them, so it’s my only two options.
I say recycle them.
But wow, I hope you have a lot of lights!
^ this
How long do you think the new ones last with/without charging? I have heard one place that they have a shelf life of 10 years?
Can I store them for 10 years without charging?
I have many Sanyos, Tenergies, and Hi-Maxs - not to mention Panasonics - from early 2011. These have seen many charge cycles and only with one or two did I notice a decrease in capacity before finally deciding to recycle them. I wouldn't worry about that. That ten-year estimate sounds about right.
Sell them to ultrafire so they can sell them as new. They sound better than what they’re selling…
If you store some, charge/discharge them to 3.8 volts and they will keep much better.
I’d keep them if I was you for an emergency. You never know when a big ice storm will take out your power for over a week. Either that or gift them to a BLF member on your continent who will pay for the shipping.
Toss ’em.
Second question.
I just took apart two battery packs from my old Dell computer. There was 6 x batteries in each pack. They was totally discharged, but charged fast up again, and then I have tested them with my BT-C3100.
The first 6 x batteries was Green Sony US18650GR 2500mAh batteries. They all got rated around 2300-2450mAh. Tested them on both 500 mA and 1000 mA and on my liitka also. Same result.
On the second battery pack, it was 6 x dark red batteries with a green ring on the top around the button. They are protected. They have no markings, beside a large D on it side, a serial number (it’s different on all batteries) and ingraved in the plastic (not printed on) this: J18A.
It’s looks like Sanyo batteries, since they also have that large capital letter printed on the.
I have used a charge - discharge - charge test on them, and here is the result, so they are most likely 2500 (or 2600) mAh batteries:
Charge results
Seems like totally fine batteries, but they are old. I did buy that computer in 2004/2005. So keep - or not to keep?
What was the voltage? Below a certain point they supposedly become internally damaged and are a risk.
Most was under 3 V - as low as 2V. But they charged up to 3V+ within a minute or two. The computer has not been used for 3-4 years.
I first charged them on my Nitecore D4, then I moved them to the C3100, starting a charge - discharge - charge test lasting for hours.
They really seems fine.
But you are telling me that there is some danger using this batteries?
Charge them fully and let them sit. Go back in a week or two and any that are not holding a charge get rid of. If they are holding a full or nearly full charge they are worth something to somebody. If you do plan on keeping them then discharge them to around 3.8 or so and store them in a cool place.
I have tested and sold a few thousand batteries. The absolute best way to tell if a battery is worth saving is to test them after at least a week. Bad batteries will drop voltage quickly when sitting. If they drop like that they are not safe to use. I have seen it time after time with batteries that look like they are worth saving.
Also just in case anyone is wondering you can test laptop packs with a multimeter and without ripping the case apart. The part where the pack makes contact with the computer can be bent/broken to one side so your leads will fit in and give you your reading. Personally I don’t bother pulling apart packs unless they are showing close to 4 volts/battery. 8volts or 12volts respectively. Now it’s possible that someone ran the battery down before getting rid of it but it seems that most of the time this simply isn’t the case. Also any of them that are below 3 volts/battery are just not worth messing with, I wouldn’t even charge them because they could be dangerous to charge. However, if a laptop pack has been sitting without a charge for a long time and the batteries are in the 4volt each range then you have a very strong indication that they are decent batteries and worth salvaging. Still, after that, take each battery out, charge fully and test again a week later. This is good advice for people with and without a charger with mAh testing capabilities.
Good luck with your batteries and if you want to get rid of some of the high amp ones shoot me a PM.
Also consider that if you have the Flying Fish charger you probably also have an mR function. while not technically an iR function it does seem to provide useful info when comparing different cells on the same charger/bay.
I have seen that the “better” cells have a lower mR and cheap cells carry a higher number. Where you draw the line is up to you but I suspect that the higher mR numbered cells will correlate to the higher rate of voltage loss over time.
Got a new package from China today, with 92 batteries in it. 29 x NCR18650BE protected, and 29 x NCR18650BE unprotected + lots of different types, mostly 4 x of each type.
Have some testing to do the next days. Will of course not test every battery, but I will test a random selection, and every type I only have 4 x of.
I think it would be better to call you the
“scandinavian connection”
Find a way to post them on “Lems” list (like Craigs list) :slight_smile: and trade for aquavit or amber.
Really you have way too many, somone close must be able to put your olds ones to good use hey maybe a velomobile battery pack?
wow good whateverfires.future collectors items?
i would save for less demanding lights and uses where they might not make it home.like junky lights for loaners or where they might get lost,dropped overboard,ect.
