Found this on Ebay, only a few hours left:
Keygos M13a: Parachord 2 x 26650 or 2 x 18650 $25.27
http://www.ebay.com/itm/110832073360?ssPageName=STRK:MEWAX:IT&\_trksid=p3984.m1438.l2649
Interest was peaked until this puzzling modes:
high / strobe / sos + gradua / change of brightness
No Low, but “change of brightness”?
Hope shows up again with some explanation.
This is popular in Diving Lights, and got adopted into land based torches. Acts just like a standard dimmer switch…
I have an M13. It has infinitely variable ramping mode change by pressing and holding the tailswitch.
It’s a great solid torch. Pretty much it’s a 2 cell M10 with stainless bezel and different user interface.
No
it’s exaggerated, or Chinese lumens.
The M13 is, however, a well made very bright torch. As good as any C8 sized reflector in throw and brightness.
For some reason, I always thought the m13 was the zoomy.
It sounds like a similar set up to my nodded m10’s, except my blinkies are much better hidden and you get the option of 3 modes too, all controlled off the tail cap.
Definitely better than the stock m10 driver set up, this should be a good buy, with real good run time on two decent 26650 cells, and the keygos’s I’ve pulled apart have all been very well designed and assembled. I like that brass pill too.
Must resist….
How is the throw in comparison to Fandyfire HD 2010 or Small Sun ZY-T08?
Due to reflector diameter, I would suspect significantly less, xm-l’s seem to love a big reflector, this is smaller than a mag d head.
Looked up the diameters:
HD 2010, ZY-T08 — 6.3 / 6.1 cm
C8 ——————— 4.5 / 4.6 cm
M10, M13 ———— 4.3 / 4.4 cm
No contest.
No, but that doesn’t make it a bad light, whilst I don’t have this one, I do have an m10 and they are a usefull well built tool, I would easily stack them up against older maglites in build quality and design. They have plenty of mass too them, good pill and feel right in the hand. Yeah, its not an out and out thrower and at two cell, its not a convenient pocket light, but if I was a security guard, this would be on my short list as a duty light - good run time and a good size too.
