keygos KE-1600 questions - please help
Hi
My name is Wallace from Italy, and I have a couple of questions regarding the not-so-famous keygos KE-1600.
I bought it on the bay for 15$ dollars with shipping, and I surely can’t complain the buy.
It is a big flashlight with a power that is well over the usual chinese XML leds mounted on C8 flashlights, but for the same price.
I only have one problem and one question:
1) the led is not centered and would like to fix it, but I really does not know how to open the head.
Any idea?
2) the flashlight uses an extension tube that seems made to be put away if needed.
But it is too short! It is long as one 16340 battery, not as a 18650!
I never had the courage to use the flashlight with three 16340 batteries (as the extension tube presence seems to suggest).
Do you know how if I can, or what’s the purpose of this non-sense extension tube?
I don’t have that light, but there’s some discussion about removing the head here:
It appears you have to be careful because of the wires and also, the threads are glued.
EDIT: You might ask the seller about the tube? Or, maybe it’s so you can use the light with the shorter tube by itself?
Does the light run on 1 or 2 18650 WITHOUT the extension tube?
This flashlight uses two 18650 WITH it’s extension tube (that is long as one 16340).
So, WITHOUT the extension tube, the space is like:
3X16340
or
1x16340 + 1X18650 (which is absolutely wrong, just to explain better…)
