Ahhh, I was hoping the gf would buy me this for Christmas. Would never come in time at this rate.
My order is in with Battery Junction/shore power (U.S. Retailer) with an expected ship date of 20 December. I am hoping for that but I understand there have been delays before. I am really anticipating this light! I am a thrower junkie and near 100,000 candlepower out of a light this size is quite enticing!
I really hope there are many more offerings from this LED (XHP35).
I see a tracking number on the website stating it was shipped the 12th…
Mine from BG just shipped!
Still no review…
I’ve had mine for more than a week. It’s just OK. I’m picky on UI and this one is crazy. I’ve switched to to Outdoor mode from Tactical, and it’s a bit better for my usage, but the way the two buttons work is a bit crazy. You would think if you activated it with the secondary button held it for low, then hit the primary button it would turn off, but no… you get turbo. Essentially if you activate with secondary in OD mode then it is best to turn it off with secondary, but that required a long press, not a click.
I could go on, but the UI is just not for me.
The magnetic charger connector is not very secure easy for it to slightly lose connection just breathing on it be prepared to position the light just so… the stiffer your USB charge cable it the harder it will be to ensure it does not lose connection before it finishes. On the plus side, the light inside the charger connector fob is really nice.
The light is very light weight, that may mean it’s heat dissipation capabilities are quite limited.
Have not done much real testing with it, but I’m looking for another small-ish thrower.
Mange tak
