Specifications
- Overall Length: 21.348cm \ 8.46"
- Blade Length: 9.09 cm \3.58"
- Cutting Edge: 8.6 \ 3.39"
- Blade Width: 2.6cm \ 1.04"
- Blade Thickness: 0,35cm \ 0.138"
- Blade Material: D2
- Hardness: 59-61
- Blade Style: Drop Point
- Blade Grind: Flat
- Finish: Satin \ Blackwash
- Handle Length:12.4cm \4.88"
- Handle Width:3,05cm \1.20"
- Handle Thickness: 1,27cm \ 0.50"
- Handle Material: Carbon Fiber, G-10
- Color: Black, Gray
- Weight: 136g \ 4.797 oz.
- Pocket Clip: Tip-Up
- Opener: Flipper
- Pivot Type: Ceramic Ball Bearings
- Lock Type: Liner Lock
PETRIFIED FISH PFB03 Stamp at AMAZON | ALIEXRESS | PETRIFIED FISH OFFICIAL WEBSITE
PACKAGE AND LOOK
As many other PF knives, this one comes in a black, textured sealed box tucked inside a slipcover featuring a die-cut brand name. It isn’t a luxury design, but the packaging is certainly decent, and it looks good enough from a standpoint of gift as well.
The kit includes:
- Petrified Fish PFB03GAS knife
- Cleaning cloth
- Sticker
- Packet with silica gel balls
- Several spare screws
Of all the Petrified Fish knives I’ve held, this one is the largest. Consequently, it is the best suited for actual cutting or processing tasks - in other words, for real work, rather than just being carried in a pocket as a typical EDC accessory which is the answer to “which pretty knife shall I pick today?”
The reverse is also true: relatively small knives handle a multitude of minor tasks perfectly well, and they are also more convenient to carry in a pocket.
In terms of design, there’s nothing unusual here either. It’s just a knife. Sure, it’s not entirely faceless - you’d certainly be able to pick PFB03GAS out from a few dozen other knives , but there’s no “WOW!” about its appearance . It’s a perfectly predictable approach to design, considering it’s a tool.
All in all, for me, the PFB03GAS is more of a practical item than just a piece of an EDC kit. Its size makes it more of a tool than merely an attractive object. I should clarify: it’s not a large knife at all, but it is somewhat bigger than the average folding knife - just take a look.
The handle scales are made of fiberglass laminate G10 , i think that is the most obvious choice.
The grip is comfortable. Edges of handle scales are beveled, nothing digs into the palm .
The lanyard hole is wide and positioned right at the edge of the handle, next to the pocket clip. Alternatively, a lanyard can be threaded through the opening in the clip itself. The clip is very basic, with no fancy design elements or premium materials. It’s fair to say that its placement doesn’t really allow for deep-carry of the knife. I have nothing against a simple design, but I honestly don’t understand why the clip couldn’t have been placed on the opposite side.
As usually, Petrified Fish logo is engraved on the head of the nut into which the screw holding the blade is threaded.
Right above it, you can see a small fin for opening the knife.
This flipper is perfectly sufficient for me, but I still can’t understand why the manufacturer opted against such an obvious opening mechanism as a thumb stud for PFB03GAS . It wouldn’t have been difficult to implement from a production standpoint, nor would it have significantly affected the price.
In any case, this flipper works absolutely superbly (as is also true for the manufacturer’s other knives), thanks to the ceramic bearings and the attention paid to build quality. A light press on the flipper is all it takes for the blade to spring right out. The movement in both directions is exceptionally smooth, consistent, and fluid. There are no creaks, no blade play in any position, and no points where the blade’s motion begins to drag. The action is perfect.
In this case, i must mention that the size and weight of the blade are actually an advantage. The increased leverage and mass boost the angular velocity of the knife tip, causing it to catapult out of the handle. It also folds back in faster than other knives, a fact I discovered firsthand when it sliced the skin over my thumb joint.
You can see this in action in the final part of the video review.
The model name and type of steel are marked on one side of the blade base.
The drop point blade is perfectly centered. It is crafted from D2 steel, a popular choice in the mid-range segment. Its typical hardness range is 59-62 HRC.
Due to large radius of blade, i feel it has great potential for slicing, not sure i can pick a proper word in english…As all the other petrified fish knives i`ve got, this is razor-sharp right out from the box. There is choice of blackwash or satin blade, i prefer last one.
Ive also inspected blade it with macro lense, there are no defects of sharpening. Of course, that is not a "mirror" polishing, but im not sure you can get it in such for such a price (if any large manufacturer offers it at all)
The knife is quite easy to disassembled, so maintenance will be simple. As many other knives, PFB03GAS has the same anatomy: it`s body has circular cutouts for weight reduction, and two ceramic bearings to provide the blade’s effortless, smooth action.
Overall
As with other knives from Pertrified Fish, I sincerely like this one. In fact, PFB03 might well be the most practical of those that i have, considering what a knife is actually meant to do - namely, cut and slice. Its blade size and shape are perfectly suited for that.
PFB03 isn’t the kind of knife you’d carry around just to admire or show off to your friends. It’s not exactly sized for convenient pocket carry, either. It is a affordable and reliable workhorse , capable of handling much more than just opening a box, slicing sausage for a sandwich, or cutting a piece of string. To draw an analogy from the world of flashlights, it’s like a mid-sized model powered by a 21700 batter. Something like Sofirn SP35 or Convoy M21.
Bulkier than what you’d typically slip into your pocket, but it’s also capable of sustaining higher brightness levels far better than a compact everyday-carry (EDC) turbo-blitz
Nevertheless, one feature of PFB03 just mesmerized me. I mean speed of blade. As i have written, it jump out, and literally feel pressure of blade when it stops. I just open-fold, open-fold, opel-fold this knife to enjoy its softness and speed of its move.
The last minute of PFB03 video review shows how blade moves and how sharp it is. Though i appreciate, if you see full video (that is just 3 minutes long) and like it.
