Hey, guys. That is forum about flashlights, but i bet that total majority of you has a knife as well. And some have way more then one. Thats like flashlights, itis not easy to stop collective them, once you`ve got 2-3…
So, let me show you a recent model by a brand that some of you may already know. If you don`t, well, this will be a chance to introduce it. So, welcome Petrified Fish PFE20 aka "Bat "
Specifications
- Model: PFE20 Bat
- Type: Folding, modified tanto with dual thumbstuds and flipper
- Blade Steel: Bohler N690, HRC 59-61, black stonewashed finish
- Overall Length: 19.2 cm \ 7.55"
- Blade Length: 8.3 cm \ 3,26"
- Closed Length: 11.1 cm \ 4.37"
- Blade Width: 2.8 cm \ 1.1"
- Blade Thickness: 3 mm \ 1.18"
- Handle: G10 (including Gmascus), Aluminium foil
- Locking System: Liner lock
- Accessories: Reversible deep-carry pocket clip, glass breaking tip
- Blade material: N690
- Blade hardness: HRC 59–61 (Hardness may decrease by 1 HRC with vacuum titanium coating).
- Blade grind: Flat
- Blade finish: Black PVD coating, stonewash / satin / stonewash
- Pivot system: Ceramic ball bearings
- Weight with G10 scales: 97 g (3.42 oz)
PACKAGE AND LOOK
Unlike many other knives by Petrified Fish , the “Bat” model comes in a plain black cardboard box without the blue outer sleeve with it`s good looking die-cut lettering that form out the brand name. That is no difference for personal use, but I would definitely have preferred that sleeve for situation when knife is supposed to be a gift . Fortunately, the manufacturer did retain the embossed detailing, which certainly gives the packaging a more premium feel.
The rear side of box if sealed. So you`ll be the really 1st user. I believe that attention to details is always a promising sign. If manufacturer pays attention to minor features of the packaging, i can reasonably expect that they have devoted just as much care to the contents. What am I getting at? Just look at the logo - petrified fish. Could they have done without it? Of course. But the logo is there, and it’s not merely printed; it’s embossed onto the packaging.
The kit includes:
- Carry pouch
- Petrified Fish “Bat” knife
- Cleaning cloth
- Sticker
- Glass breaking tip
- 2 spair screws
- Packet with silica gel balls
“Bat” is one of top-models among the knives by Petrified Fish, so it got carry pouch. That is certainly not cheap one. The material is heavy-duty; I think it’s a type of Cordura. The interior is lined with a fur-like material. The hardware is water-resistant. The stitching is flawless.strong text
This model comes in several versions featuring different materials and designs for the handle scales and blade finish. In my case, they are purple G-10 scales styled to resemble multi-layered Damascus texture , this is known as “Gmascus.”
There is also choice of Aluminium foil and simple G10 scales.
The “Bat” is a medium-sized folding knife. There are larger and smaller models available. In this regard, it is a fairly versatile knife suitable for both urban environments and the outdoors.
The grip is comfortable. The handle scales feature beveled edges, so nothing digs into the palm (including the pocket clip, which is imperceptible when i hold knife). The fingers fit precisely into the corresponding grooves.
I hadn’t handled knives by Petrified Fish before, but all the feedback I’d read about them: build quality, edge sharpness, and grip comfort, was very promising. And indeed, the reviews were spot on. The knife not only looks great but is also flawlessly constructed and assembled. The handle scales aren’t smooth; G10 has feature a tangible micro-texture that you can feel when running a fingernail or finger across them. The finishing of the scales is impeccable. Nothing protrudes, there are no gaps, and all the edges are beveled.
I`ve made a lot of pics to show you how Petrified Fish PFE20 Bat looks. Normally, i would limit their amount to 3-4, but i cannot choose which one to delete, so here is the whole bunch featuring Acebeam P20 mini and Wurkkos HD02 Pro on the background.
As you can see, the clip is positioned right at the very edge of the knife, allowing it to be completely concealed in the pocket - a feature that fans of deep-carry knives will appreciate. I also really liked that there is a small dedicated recess in the handle scale for the clip; when I slip the knife into my pocket, absolutely nothing snags on it.
As you may have gathered, the clip can be mounted on either side of the knife or removed entirely if desired. I should also note that the knife lacks a lanyard hole, so any lanyard would have to be attached to the clip. I have no explanation for this, as I certainly believe there is enough space for a lanyard hole at the rear of the knife .
Kit also includes pair of spare o-rings, which you can screw into unused recess at opposide side of the clip.
Speaking of the rear of the knife, I should mention that a replaceable glass-breaker attachment is included. I highly doubt I’ll ever actually need it, but I installed it anyway for one simple reason: it protrudes only slightly from the handle and doesn’t get in the way at all. Plus, since it isn’t really sharp, there’s no risk of it damaging the lining of a jacket or shorts pocket.
You can use this funny small screwdriver from a kit to insert glassbreaker even on the go.
There are two ways to open knife: flipper or any of both thumbstuds (so, yeah, the knife is reasonably ambidextrous). The knife uses ceramic ball bearings ( i will show it below), so blade move is soooo smooth and fast. I apply just a light touch to the flipper, and the blade literally springs out, making a pleasant click as it locks. You`ll see it below in the video. Of course, the flipper has notches to prevent your finger from slipping off it as well as there are jimping right after the flipper.
Knife uses liner lock system. The groove with notches at this part of locking mechanism is really convenient for finger.
The blade is perfectly centered.
The version that i`ve got has blade with Black PVD Stonewashed finish. But all the knives are made of Böhler N690 steel. This steel is known for a balance of corrosion resistance, edge retention, and ease of maintenance.
There is a tiny print with the model name “PFE20” right in the beginning of the blade
Blade
As you can see, that is a specific blade - modified tanto. Well, for me that is like LEP flashlight. Very specific blade geometry for specific needs. It is really good for certain task, and way worse for other.
Tanto blades are well-known for being super strong. This shape is good for piercing while keeping the end of blade intact. And, well, that is tempting to use knife for prying, though that is risky for blade. Many blade tips were broken in attempts to pry something open. Tanto is quite good in keeping blade.
The triangular tip of the tanto blade enables it to have a secondary tip alongside the initial point of the blade. This can be used for more precise cuts.
So, this is sort of blade you will not keep in pocket to slice bread (i mean it can do it, of course), but rather to some serious, more aggressive work: chopping or piercing.
Sharpness. Yes, it’s not a “mirror” polish, but the knife can shave hair, slice paper, and cut through the soft skin of a rotten tomato right out of the box. Flat grind.
Take a look at video below this review, you`ll see it.
Disassembling
You`ll need to unscrew screw from the opposide side of the logo, remove tip from the finis of knife and unscrew couple of screws that hold pocket clip.
I couldnt fully disassemble knife, but i was able to do it to the point you can see most part of its insides. The only thing that i have no access is bearing. Let me remember, there should be ceramic ball bearing. This bearing gives you soooo smooth and rapid fold-uhfold move in usual urban use this, blade really springs out. But i admit that some dirt can get inside bearing during some really active use. I suppose that usual spacer would rather be more useful instead of ceramic call bearing. Yes, blade move will be far less smooth and fast. But that is a price of ability to use in really harsh condition. Of course, i may be mistaken.
PROs
- build quality
- kits includes everything you need
- glass breaking tip
- perfect sharpness out of the box
CONs
- simple pocket clip. there are some cheaper PF knives that have more attractive clip. that is not really CON, but i need to find at least anything.
- lanyard loop only in clip
And here is a short video review, that shows how quick and smooth blade moves, and also sharpness right out of the box.
