A quick runtime thing of the Kosen M31LL, they all essentially had the same runtime.
10+ year old eneloops, tested to 1846mAh, average.
Don’t mind the crazy spikes, I didn’t have my lightbox, so ambient light, ceiling light, etc. disrupted the brightness throughout the test. 7 solid hours isn’t bad, for an average of 55 lumens on the M31WLL and 76 lumens for the M31NLL, as per the Ceiling bounce app. Outside of that was a rapid drop to 15 lumens, then a very rapid decline.
In a lumenhours sense, that’s pretty good…
M31WLL 2700k or M31NLL-DD, ~2900k
55×7=385lmhrs
M31NLL 3500k
76×7=532lmhrs. That seems pretty efficient to me! Maybe not quite freeman driver efficient, but pretty efficient given the warmer CCT LED’s. (519A)
2AA’s. I think it’ll function with one, but don’t have a dedicated body to test that yet. For more modern neutral or cooler CCT LEDs in an efficient driver with the most efficient possible modes (like thefreeman driver in a d3aa) I’ve generally seen that for a 2500mAh rated NiMH cell:
1AA puts out up to around 350 lumenhours (average 250)
2AA puts out up to around 650 lumenhours
(average 550)
Any signicant deviation from such, say, 30%+, is either exceptionally outstanding, which indicates to me that something might not be running as described, or exceptionally poor, which could be a cell issue if other ones function as expected.
How are you establishing the initial lumens, or the amount to scale the ceilingbounce run by? Kosen claims 125 and 100 lumens, which to me seemed ridiculous when a single L M31 makes about that.
You got a little more than twice the runtime (180 mins almost exactly) I got w/ the M31L 219b, which seems pretty reasonable.
I’m “calibrating” to other factory lights that state “x” lumens. They’re flood, throw, etc…There’s one spot in this room that gives a pretty consistent reading regardless which light it is, and that’s where I try to ceiling bounce at night. Keep in mind, if we presume that most factory lights are overrated by 10% (which I would be more inclined to disagree about) then that would roughly drop the kosen lumens to about 60ish dedomed.
With 2 freshly charged NiMH on a stock dome Kosen 3500k m31NLL, I’m getting 86-92 lumens initially, and around 72 lumens settled. With a me-dedomed/re"domed" variant of the same build, I’m getting 58 initial 2× NiMH, 48 settled.
I believe the 100 lumen rating is off of primaries, such as alkalines, as 2×l91 gives me roughly 150 lumens initially, and 140ish lumens ramping down to 115ish for the “main” portion of the test before a voltage deregulation dropdown occurs.
I can confidently state that the 70ish average lumens for 6-7 hours on decent NiMH is accurate, and that is being conservative on the lumens, lol.
As for the double runtime and same brightness as the m31L variant, I don’t know…Running a single cell on the LL allowed for around 2/5 the runtime for alkalines and NiMH, but 1/2 the runtime for lithium variants. I think it might have something to do with the voltage input?
Well, your measurements don’t put it at the same brightness. I get around 110 lumens on Eneloops w/ a Texas Ace lumen tube. I don’t recall anymore what the manufacture rating was, and Illumn doesn’t list them anymore. I think it was 650mA and 125 lumens, but I also recall some of the later 219b drop-ins had unusual/non-standard current draws for some reason.
I think you’re right, there were a few iterations of LLL and LLLL, some at 50 lumens, some at 25…As for the 219 LL being around 125 lumens @650mA, that sounds about right.
As for the NiMH outputs, the only time they come close to 100 lumens is off a fresh charge, but my current assortment of NiMH have been all over the place, with only one pair of good 1900mAh blues still in my possession. (the white ones seem to have been fakes, purchased from the “River” Company) For the NiMH that charge to higher voltages, i.e. 1.51V, it does indeed hit 100 lumens, but quickly drops back down to the 80’s before settling into the 70’s. I’m inclined to believe that the circuit was optimized for non-rechargeables like Lithiums and Alkalines…In a situation where I might be stuck without power/cell access for longer than 10 hours, I’d probably main some Lithiums then alkalines as backups. The “limp” mode portion outside of regulation for primaries really is enough light to get you home, especially if you cycle the cells out for resting time.
As for the maffs…
On 2×NiMH
219m31L: 125 @ 650mA
519m31LL: 70 @ 300mA
Numbers seem about right. I’m still holding out hope for an m31LLLNT (Narrow TIR thrower), rated at 60L(probably 40ish with NiMH) Which should run for about 12 hours before dropping out of regulation. That would be enough to get me through a full “shift” if necessary, then plenty of limp mode to find some more batteries. I tell you, in any case, walking around long empty stretches of suburban road is no fun with less than 100 lumens, especially if the lumens aren’t particularly punchy…
I would LOVE for Kosen to release an M31LLL with 60Lumens of High CRI, Narrow TIR (<=5º) 3500k (519A) or 5000k (sft25R-WG). Paired with a Hi-Lo MDX3, my ideal EOWSHTF light. I estimate about 5kcd, which I could always soften up with some dcfix…
TIRs tend to lose more light than reflectors. In a low output one, I might want the most light making it out the front I could get.
Now I’m starting to regret not grabbing an M31LL from Illumn when they were available. At the time I felt a light <100 lumens max was not that compelling. Not that I don’t often use less than that, but if that is the most it can do… But more than twice the runtime and not that much output loss is tempting. I don’t like the domed 519a though. It’s generally too floody for me and in the lights I’ve had it’s never been that pleasant a tint.
I use my M31L in an MD3, but the high/low didn’t work for me. Though I’ve since heard if you start on high to get it to turn on, it’s more likely to work on low. I never tried that.
Yeah, usually when I go for a walk at night I like to use 10 lumens or less, just enough to see 6-10’ in front of me so I don’t step on something. I still want to retain night adapted eyes, I love seeing the stars and even hearing sounds in the brush w/out knowing exactly what it is. But now and then I want to actually see, and if it can’t hit 10-20,000 candela it’s not going to be useful for that. Even the regular M61N w/ SST-20, I don’t think it’s that great outdoors for that. It’s not enough throw to make out deer across my yard. So I feel like no matter what, these lights are a compromise. For some reason I settled on ~100 lumens as being a good compromise. But your runtime is pretty sweet.
With the high low, if i keep it on loose, i just press the head into my chest or palm to momentary the high…taking the pressure off allows it to return to low before i use it, so it preserves dark adapted vision.
I feel like the sft25r-wg(high cri) could throw decently in the stock reflector; some similarly sized LED variant is in the oclip pro, and that tiny reflector yields a pretty punchy and focused beam. Diameter is a little more than half, depth is about 1/4, LES surface is about half a dedomed 519A, and yet the hotspot is roughly the same size as the m31LL 519A. Properly heighted and centered, this type of LED might outthrow the 519A by a substantial margin, even with less overall lumens…
