Imago
(Anton)
November 16, 2023, 2:15pm
1
Heyho
Today I flashed some of my Flashlights with a new Anduril Version.
But my KR4 doesn´t work after flashing it. When I reassemble it it flickers a little, gets very bright and then turns off
I updated it with the android app & Hanks tool.
Old Version: 2022/10/21/0216
New Version: 2023/10/31.noctigon-kr4-boost.hex
Ty for your help!
Valynor
(Valynor)
November 16, 2023, 2:23pm
2
Did you try a factory reset (13H)?
Are you sure you got the model ID (0216) correctly?
That usually what happens when you do a factory reset.
Imago
(Anton)
November 16, 2023, 2:27pm
3
Yes and yes. I tried factory reset but after the initial flickering there is no more signal coming from the lamp.
Before I flashed the firmware I double checked the previous Version. And I know its a kr4 with boost upgrade
Valynor
(Valynor)
November 16, 2023, 2:30pm
4
OK. It seems something is pressing the switch (or closing the electrical contact) so that the light “thinks” the switch gets pressed permanently (which would do a factory reset on re-assembly).
Take the light apart again and look for something that could be causing that.
Screw everything back together tightly.
Imago
(Anton)
November 16, 2023, 2:43pm
5
No I don’t think so. I reflashed the old version and it works fine again. So if there would be a hardware issue that would not change with the UI Version, right?
Valynor
(Valynor)
November 16, 2023, 2:48pm
6
Hard to tell because you took the light apart and reflashed it.
To know for sure maybe redownload and reflash https://toykeeper.net/torches/fsm/anduril2/anduril.2023-10-31.noctigon-kr4-boost.hex again.
Imago
(Anton)
November 16, 2023, 3:41pm
7
I downloaded that file twice ind tried to install it 3 times
But now working is the -12V version and not the boost. Does that change sth.?
Valynor
(Valynor)
November 16, 2023, 3:56pm
8
Should be the same version (got renamed to -boost recently).
But I think this could be an issue @ToyKeeper might want to know about.
elendur
(elendur)
November 20, 2023, 12:33am
9
I also can’t use the new hex with my kr1 with the boost driver that uses the same kr4-boost firmware (and confirmed by 13c version check).
It acts as if the switch gets stuck once it is pressed.
I commented about it in the “anduril…2?” thread.
