KronoReview of the LuckySun D80 . This item was provided by GearBest/Karen for review.
I previoisly reviewed the LuckySun P26650-L2 , and liked it a lot. Does the little bro’ D80 have what it takes to outdo it’s older sibling? Let’s see. A little info from Gearbest first:
GearBest regular price: $24.17.
(No website for LuckySun or Neco Nature…apparently same company)
Specifications (From GearBest product page):
Brand: LuckySun
Model: D80
Emitter Type: XM-L U2
Total Emitter: 1 x Cree XML U2
Lumens: 1100lm
Feature: Lanyard
Function: Walking, Night Riding, Hunting, Exploring, Camping, Hiking
Battery Type: 18650
Battery Quantity: 1 x 18650 battery (not included)
Mode: 5 (High > Mid > Low > Strobe > SOS) Incorrect
Focus: No
Rechargeable: No
Waterproof: IPX-7 Standard Waterproof
Reflector: Aluminum Smooth Reflector
Lens: Toughened Ultra-clear Glass Lens with Anti-reflective Coating
Dimension and Weight:
Product weight: 0.126 kg
Package weight: 0.306 kg
Product size (L x W x H ): 12.8 (length) x 4.1 (dia. of head) x 2.5 (dia. of body) cm / 5.04 x 1.61 x 0.98 inches
Package size (L x W x H ): 18 x 14 x 7 cm
Package Contents: 1 x Flashlight, 1 x Lanyard
My added specs:
Lens OD: 39mm
Lens thickness: ~2mm
Emitter star OD: 20mm
Turbo/4 amps !
High/2.4 amps
Med/1.0 amps
DBCstm’s measurements (Thanks Dale!)
Reflector diameter: 36.2mm
Reflector height: 21.6mm
Reflector tapered base diameter: 15.8mm
Emitter hole diameter: 8.1mm
KRONOREVIEW:
The LuckySun D80 is a single 18650 flashlight with a single XM-L emitter. The flashlight comes with a nice lanyard. It is shipped with ample protection in a sturdy, retail cardboard box. Light is controlled with a tailcap reverse clicky. There are 6 modes, starts on high (no memory) and UI is (H/M/L/Strobe/Turbo/SOS). It has a SS bezel, excellent AR lens and flawless, smooth reflector.
HIGH-LIGHTS:
VERY solid construction.
Toughened, thick, glass AR lens.
Lots of machined ridges provide ample grip.
Deep cut cooling fins.
Scalloped cutouts on rear of fins provide anti-roll feature.
HA-III matte gun-metal gray coating.
Reverse polarity protection (confirmed).
Solid emitter shelf. Should have a decent thermal path.
Anodized threads enabling lockout.
Pleasant beam pattern with a quick, but smooth transition from corona to spill.
Squared threads.
Fits protected or un-protected 18650s.
Reverse clicky with half-press advance.
4.0 amps on Turbo! WOW!
LOW-LIGHTS:
6 mode, funky UI (High/Medium/Low/Blinkies/Turbo/SOS).
XM-L
Little to no thread lube.
Clicky button is too thick and prevents tailstanding.
Head o-ring mounted behind lens instead of in front.
PICTURES
Packaged in a nice, retail cardboard box.
Well protected on inside with ample foam packing. Just light and lanyard.
Standing on bezel. Hard to notice, but ’NECO is printed on button.
Tailstanding, very unstably due to ‘bulging button’.
Sideview.
Head separated and logo closeup.
Separated into 3 pieces.
Square threads.
Cathode side. Button with outer rim instead of spring. Notice the normal ‘s’ on logo (not reversed like it was on the P26650-L2).
LED view.
In hand. Nice size and very compact for such a bright light.
Comparo pics for size. Convoy C8 and D80.
Tailcap end. Nice lanyard relief, but not too useful when button interferes w/tailstanding. I will try to trim inside of button and see if that resolves the issue.
Quality lanyard.
DECONSTRUCTION
Tailcap parts.
Annodized internal threads with bare Aluminum shelf. Shelf contacts brass retainer of cathode side of driver.
Anode spring.
Omten PBS-101C switch. Nice, brass retaining ring underneath. Love the 6 indentions on their retainer rings. They look good and provide more ‘chances’ in case you bugger up the others.
Emitter. Bezel and AR lens removed. Unable to remove reflector. Seemed to be wedged down by o-ring. May try later
Driver pics. Solid shelf in background with small dimple in center. Thermal path should be quite good for high amp turbo mode.
Inside tailcap. Anode spring and backwards ‘digital light’ logo. I like it when manufacturers don’t use off the shelf parts. It’s a nice touch and shows some pride by the maker.
BEAMSHOTS/NIGHTSHOTS:
Beamshot closeup on stained concrete floor.
Control shot.
Turbo beam shot. (4.0 amps!) Lights it up really well.
High beam shot. 2.4 amps.
Medium beam shot. 1.0 amps.
Low beam shot. Amps unknown…wouldn’t show on my DMM.
SUMMARY
This is a stellar light from LuckySun. Quality HA-III anodization in a nice gun-metal gray, square cut threads, intricate brass driver and tailcap retaining rings, decent thermal path, lockout, and 4 amps!!! Machining quality is excellent. And even though it is a single 18650, it puts out an amazing amount of light while maintaining pocketability. The UI is not my favorite. It also uses a first gen XM-L. However, perhaps that is a good thing considering the inability of some newer XM-L2s to pull high amps. With some minor changes, the LuckySun D80 would make an exceptional BLF SE torch (hint, hint). Overall, a monster of a little light!
KRONOMETER patented rating: 4.25 out of 5.
Surprisingly even without mode memory (on the stock version) I do like it and where it starts but not sure if I would use it at work without memory.
