Hello all. I am amazed at how this is coming together. Thanks again for all your patience!
Thanks to JM, unknown and Dale, we have a huge amount of info on this light…and some crazy tests! My sample came in a day later than theirs, and I am just now getting to take pictures.
There won’t be a long review, just some thoughts and pics. My overall opinion is…WOW!!! How could an inexpensive light have so much to offer? Well…I don’t know. But Eagle Eye/BG is doing it.
No…it’s not perfect. Nevertheless, this is truly a Budget Flashlight that delivers…big time! Here are some pros:
>Excellent size. Very comfortable in hand with no sharp edges. Classic, simple looking design. I was expecting it to be the size of a C8, but it is surprisingly much smaller.
>Anodization seems to be on par with many flashlights at 2 to 3 times the price. Mine matches perfectly from tailcap to head. A very nice flat black.
>My sample has no ramp-down…don’t know why…but I like it that way! The light gets hot after about 10 minutes on Turbo, but heat is surprisingly distributed very evenly throughout the aluminum shell. Heat dissipates very quickly when turned off.
>VERY bright for such a little light.
>I probably won’t use the clip, but it is very substantial…not flimsy like you would see on typical budget torches.
>Brass retainer rings and thick gold springs front and rear…nice!
>Reverse clicky with half-click advance.
>Lanyard is decent quality.
>Lubed threads…and lots of them…no skimpy short 2 or 3 turns when threading tube to tailcap or head. Lots of threads also for brass retainer rings.
>BLF Logo (from a distance).
>Unprotected or protected batteries…no problem. No battery ‘slop’ (rattling) when put together.
>Reflector gets about as tight as you can up against emitter…no space in between, and no raised emitter centering piece that could block light.
>Thread lock-out.
>Tailstands.
>Water Resistant (see JM’s vid).
>Friggin’ tough aluminum (see Dale’s vids).
Cons:
>AR lens is no good. Needs replacing with better AR lens or stock lens.
>Knurling could be a little ‘tackier’.
>BLF Logo looks a little ‘blocky’ up close.
>Amps not 3.5 (no way for me to test as I have Harbor Freight DMM…going off other sample tests).
Overall, this light exceeds my expectations for a light that will GB for /- $20. This light is a budget flashaholics dream at/- $30…and higher. The amps, in my opinion, are high enough. This little light screams as is. You could easily add amps, so I don’t really consider that much of a letdown. Nevertheless…I will see about getting it up to the desired 3.5 amps in the GB version.
Here are a few of my pics:
First…a little color.
Logo Close-Up.
In hand.
Nice machining on cooling fins.
Driver shots.
Driver side spring.
Main parts disassembled w/trusty SRM.
LED close-up.
Lit up.
Me trying to be artistic…and failing…lol
Nice threads…man!
Comparo shot: X6-SE, Sky Ray King & Convoy C8
Comparo shot: X6-SE & Convoy C8
Parting shot.
That’s it. Feel free to ask any questions.
Blessings/krono
