lantern or flood light?
Does anyone know of any lanterns or flood lights or dome lights that take 18650s? Basically any non flash light. Something that could flood a room with light……
Thanks!
Not that I’m aware of.
You could take almost any flashlight and a diffuser.
Or get a combo like
Sipik CK66 Cree Q5 3-Mode 180-Lumen LED Flashlight Black
or a Solarforce L2 plus the LT-1
Fenix also has some nice lampshades that converts a normal flashlight to a lantern. They fit many EDC-style lights.
http://www.fenixlight.com/ProductMore.aspx?id=63&tid=20&cid=6#.U4B4loxuvMI
But I would really like a bigger lampshade that you can place on a table and talistand any flashlight beneath. Would be great for nightly garden grillparties. And would actually give me a good reason to have flashlights. Warm tint would make it cozy. I use old kerosene pressure lamps for this purpose now, flashlights would be easier and safer.
You can easily make something similar from an empty bottle of opaque plastic and a saucer, but I would like something nicer, like a real lamp, only flashlight powered. And not designed for one specific flashlight either. Might try to pick up a second hand lamp and mod it…
I’m not exactly sure what you’re after, but I’d bet something like a Bicycle Headlight could be adapted to work without a lot of trouble.
Close?
I'm liking this a LOT.
http://www.gearbest.com/led-flashlights/pp_22717.html
Lantern head that can be attached without removing the lens (no dirt or scratches to reflector), anodized tailcap threads, 18650, plus an orange wand. It's very similar to a light I got from Banggood, except with improvements in all the areas I had issues with. Hopefully it has a solid shelf under the mcpcb and the emitter can be swapped with an XM-L2.
Turn down your volume.
For indoor use the Fenix TK76 tail standing, using the 60 degree and 120 degree wide angle lights combined, does an amazing job in my living room. The ceiling bounce off of my white ceiling does a great job of lighting up the room. Overall about the most versatile flashlight I have ever seen. I wish they also did a more compact two 18650 version as the head on the TK76 is huge and the light is quite heavy.
Why does no one do a flashlight/lantern designed to illuminate indoors via ceiling bounce? There are many lamps, particularly floor lamps, which are designed to output light either up only or up and to the sides primarily that illuminate rooms without glare and many date back 100 years or more.
The one I mentioned should do that if it's the same as the one I have. The top part of the lantern head comes off, leaving just the ping pong ball diffuser.
I have a mini lantern like that but removing the cap with the reflector cone causes a relatively small circle of light on the ceiling. It just cannot compare with the whole ceiling being illuminated by the very wide combined 60 and 120 degree beams of the Fenix TK76, totaling up to 1800 Lumens.
Mini lantern listing: Amazon.com
Note the no mention of the removable top cap except in a couple of reviews!
That's a different lantern. I don't know anything about that one. Now the one I mentioned would probably emit a smaller cone of light on the ceiling than the one I got from Banggood because the light first goes through the reflector. I'll compare them soon. Hopefully the battery tube of the CK66 will work with the lantern I have because that will eliminate the reflector and make it more efficient as a lantern, but that's not practical for anyone else since that doubles the cost.
