As per below statements, 3 & 5 are garbage so I’m charging the other to test them out.
1. measure cell voltage. if it’s less than 2.5v, throw it away.
2. charge the cell. if it gets hot during charging, throw it away.
3. measure cell voltage off the charger. verify it’s between 4.1 and 4.2v.
4. wait 30 minutes
5. measure cell voltage. if it’s fallen less than 4v, throw it away. Otherwise record the voltage.
6. store cell for 3+ days in cool, dry place.
7. measure cell voltage. if cell voltage has fallen more than .1v from the recorded voltage, throw it away.
Any cell that hasn’t been thrown away by the time I’m through with step 7, I keep and put into my regular cell rotation.
Espero se me entienda puesto que mi Ingles es nulo y es traducido a traves del Google
Yo antes de tirarlas lo que aria Seri meterles un chute de desfibrilación ; Pera intentar reanimarlas.
El sistema es simple existen dos formas que yo conozca y emplee .
Una la puenteo con otra batería en buen estado cargada a tope + con + y - con -
O bien utilizo un cargador de celular viejo mismo sistema + con + y - con -
Este puente lo realizo durante unos 3 segundos únicamente comprobando con el tester si se a subido su voltaje para que de esta manera la reconozca el cargador.
Acto seguido la pongo en el cargador eso si siempre bajo estricto control, puesto que no dejan de ser baterías recicladas y sin protección
Espero haberte ayudado Un Saludo
I hope you understand me because my English is null and is translated through the Google
I before throwing what aria Seri throw them a shot of defibrillation; Pera try reanimate.
The system is simple there are two ways that I know and use.
One the bridge with another charged battery in good condition butt + with + and - to -
Or use an old cell phone charger same system + with + and - to -
This jumper is performed for about 3 seconds only checking the tester if the voltage was raised to thereby recognize the charger.
Then I put it on the charger that if always under strict control, since they are still recycled batteries and unprotected
Hi, hola yo hablo español tambien pero no entendi nada, ja ja . Las estoy cargando con un cargador inteligente a ver que sucede (pareciera que estan agarrando la carga). Bueno gracias de todas formas.
8)
Me refería que si algunas las tienes por debajo de los 2.5 v en teoría estas muertas osea el cargador no te las reconocerá y no te las cargara.
Sin embargo si la puenteas con otra batería ,cargada durante unos segundos o con un cargador de móvil por ejemplo ; Eso le supone una subida de voltaje durante unos segundos, los suficientes para que el cargador te las reconozca y las cargue .
Esto no siempre funciona pero en un porcentaje elevado es eficaz.
Yo estoy a la espera de recibir esto , para ver si puedo averiguar el estado de las Baterias; Ya que dispongo de unas cuantas recicladas de Portátiles.
En mi opinion, para que arriesgarse con un voltaje bajo? mejor tiralas y consigue otras que tengan un voltaje mas alto, o si piensas arriesgarte y cargarlas hazlo en un lugar al aire libre donde no pueda incendiarse nada (Cemento, metal etc) donde si fallan y les sale fuego no se queme nada, solo los cables de carga.
Saludos!
AlexGT
In my opinion, why risk it? better to just throw them away and get others that have a higher voltage to start with, or if you want to risk it, do it in an open space where nothing can catch fire (concrete, metal, etc.) where if they fail and vent with fire, nothing will get damaged besides the charging cables.
