Laptop battery pack pull-interesting cut out circuit
Thought I would share this, Received a battery pack yesterday, the previous owner was getting approx 10 minutes on the laptop, after breaking open the pack thinking I would find 6 useless cells , to my surprise all six where at 4.15 volts , I ran a discharge test on my hobby chargers, all 6 cells achieved 1850mah in their respective tests, I’ve charged 2 with no heat issues so far.
The age of this pack is approx 2.5 years old, I’m thinking the manufacturer builds a cut out circuit inside to force the owner to buy a new battery pack.
1800mah is great for running single cell lights.
I've heard of this before. Reasoning I heard was that it helps ensure the customer replaces packs periodically to ensure optimum performance of their product for customer satisfaction.
Charge them fully separately, let them sit a week….test voltage
See if they self discharge rapidly, just because they charge doesn’t mean they stay charged
Thanks for reading and replying, I’m not new to laptop pulls I’ve done this more times than I can remember ,
The fact that they each equally discharged to 1800mah indicates they are decent cells , if they where going to self discharge they would have been at a lower voltage before I opened the pack and tested.
I posted this to share the fact that some old packs are actually worth retrieving, where most are junk after 2-3 years.
Did a Toshiba pack a few weeks ago where each cell was 4.2 volts out the pack and on a discharge test resulted in 80mah each, this was recycled as they are no use to anyone.
What brand / model was the laptop pack?
Honestly there seems to be no excuse for this.
absolutely most packs are worth getting, usually only one or two of the cells are the culprits in the batteries
Good job on retrieving those batteries, I just pulled 8x samsung blue ring 2600mAh batteries out of an HP battery my buddy gave me…looked online they were $9.98 a pair at ft brand new!
Laptop current draw rating 3.2A
I’ve tested them on 1, 2, and 3 amp and they are holding up fine charged my iPhone on the Coolook charger with two cells no problem.
As mentioned they are ideal for single cell lights with 1-3 amps drivers, got one in my modified Convoy M2 and it’s doing fine, it’s a Dr Jones 3A driver,
The laptop I’m using right now has long-since given up trying to remind me it’s time I “NEED” a new battery, yet I recently completed a WiFi Site Survey & repair job at a large hotel nearby, without ever plugging it in.
Recently, on one of the uncountably many threads & posts about laptop pulls, a contributor chimed in saying he had worked at a repair center & had received some training wherein it was disclosed the circuit contains some “timer” or “counter” which would assume End-Of-Life of the pack regardless of the actual State of the 18650s… I am still trying to find it, but searching this site for “laptop 18650” will keep you busy reading for far longer than any laptop battery can keep the screen lit!
However, comma, I must respectfully disagree that anything under 2000 actual mAh is very useful. To me, anyway. I only use Medium mode when High gets too hot to hold, and only use Low to look for the “low battery” blink of the (original) 105c, so any 18650s I get with that low capacity get put aside as “emergency spares”…
