Yesterday, I had some free time. So I went to work on my recently acquired laptop batteries.
First one practically fell apart. It contained 4 light purple cells. ASO GI2I091EF 81922
and a long skinny bar code. I have pull cells like these from battery banks. Unknown Mah
They were all around 2.5 volts.
Next pack, while very similar to the first, needed to be destroyed before it gave up.
It contained 6 Sanyo UR18650A R1112 . Red wrapper violet top. I believe to be 2200mah. These averaged around 2.5 volts.
Final pack was out of Dell 80 watt pack. Story is. It was bought New this year, as a replacement. The guy used it until it needed to be charged and then it wouldn’t charge.
He gave the laptop to my dad for parts. There was so much glue on this thing, I used my flush cut nippers and just opened it up like a can of tuna, or maybe soup.
It contained 9 Samsung ICR18650-24B cells in blue wrapper. I believe to be 2400mah
I was discouraged to find out they were all around 1.6 volts.
I am aware of the dangers. I am aware of the dangers. I am aware of the dangers.
Anyway, first on the Nitecore I2 were the Samsungs. They all showed full. Hmm, my charger thinks there Ni-Mh. I loaded them into the Xtar SP2, Xtar MC1, and my Tomo battery bank-charger. After 10 minutes the Nitcore I2 would charge them. I increased the charger rate on the SP2 to 1 amp. When it finished a cell, I pulled one from a slower charger.
First Samsung cam off at 11pm. Showing 4.17 volts. It went into Armytek Prime C2 Pro at level M3 (380ish lumens) I ran it at that level with jumps to Turbo (900ish) lumens until 1:30 am. Switch still flashing green on Prime. Seams fine.
OK, I had to sleep so I pulled all cells from charger and started over today.
Day 2. All finished cells have been at 4.17 volts.
The first 4 samsungs that came off charger, are Now setting at 4.15 volts. 12+ hours after charged.
The first 2 Sanyos are now 4.16 volts. 12+ hours off charger.
None of the cells got hot, not even warm. All but 3 are finished. Doing another run time on a Samsung. Started at 2:50 pm. (3 hours before flash)
Anyone want to take a guess on how they will turn out ?? Thoughts ?? Similar experiences ?
Sorry this was so long.
Chad
