laptop USB problems
hey guys i have a Dell XPS L702x laptop and i was going to install a driver programmer and once i hook the usb cable to my laptop port it beeps fast and does nothing ??? once i pool out it makes the regular disconnecting sound that it should
what might be the problem ??? i also contacted DELL and they gave me a driver to install but did not help
and i just tried another usb cable and it installed the drivers perfect ?
Hey Nitro, I assume you're talking about a USBAsp programmer? If so, you're going to need some extra drivers. Get the drivers here. I would also check out the flashlightwiki post, it is very helpful.
the programmer is the Zilog W/usb Smart cable
Sorry, no experience with that one! I know that Tom E. had some initial trouble too, but he seems to have resolved the problem.
it must just be from the programmer, i tried 2-3 different USB devices and they all get recognized and my laptop make the connection noise but not this thing
If you open up device manager does it show it when plugged in? It should show up as an unrecognized device even if the drivers aren't working correctly.
yes it shows but it gives a msg that it could not install the drivers
Then your computer is recognizing it but you need to find the drivers. You may have to tell Windows where they're at.
i just contacted the manufacturer and asked for the link to download them
GOT IT :)
i followed these steps and got it to work and thanks DMM for the help
1. Connect the USB SmartCable to the Host PC
A window message, "driver software installation" appears.
2. Windows automatically searches the driver. Sometimes, this process may
takes a long time. In this case, wait for the search to complete since
there is no option to terminate this process immediately.
If the driver was previously installed, windows automatically installs
the USB smartcable driver. Then go to step #9
If the driver was not found, click to close the search dialog and go to
step # 3
3. Enter "Device Manager" in the "Search Programs and files" from the Start Menu.
4. Right-mouse click on "USB Smart Cable" under "Other devices".
5. Select "Update Driver Software".
6. Select the option, "Browse my computer for driver Software" in the dialog,
"Update Driver Software - USB Smart Cable".
7. Browse to one of the following driver directory:
For 32-bit version:
<ZDS II Installation Directory>\device drivers\USB\x32
<ZDS II Installation CD>\device drivers\USB\x32
For 64-bit version:
<ZDS II Installation Directory>\device drivers\USB\x64
<ZDS II Installation CD>\device drivers\USB\x64
