If possible, look for the UM25/UM25C on eBay.
It’s extremely accurate, as per HKJ’s testing down to the 1/1000, rather than 1/100, and quite precise.
It can also be used with Bluetooth, which means you can log the info, and put it in an Excel file, which is very useful.
It can also handle 5A max, at up to 24V. It’s got a micro USB input, USB-C input/output as additions to the USB-A input/output. It also support USB protocol recognition. Finally, it supports USB-C PD pass through. No protocol activation/recognition though.
If you want compatibility with Dash Charge, look for the UM34/UM34C. Less accurate and less precise, but supports Dash Charge passthrough.
If you could, I would buy from the RD Tech store. They are the official manufacturer of the UM series of USB power monitors.
If you say you are from BLF, they will give you a small discount, about 5. It’s worth it IMO since I support them directly, and their customer support is great, even with a 5 higher price.
eBay link:
Aliexpress official store link:
https://www.aliexpress.com/item/RD-UM25-UM25C-for-APP-USB-2-0-Type-C-LCD-Voltmeter-ammeter-voltage-current-meter/32855845265.html?spm=2114.search0104.3.3.17f97e5bSrB3lD&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10068_10130_10547_10059_10548_10696_100031_10084_10083_10103_451_452_10618_10139_10307,searchweb201603_54,ppcSwitch_2&algo_expid=e2869c11-4b0a-44eb-b303-be5593ce0714-0&algo_pvid=e2869c11-4b0a-44eb-b303-be5593ce0714&transAbTest=ae803_1&priceBeautifyAB=0
Both the UM25/UM34 can log in the resistance of the cable using a USB electronic load.
