Latest and greatest dive lights?
It’s a bit more ‘rocket science’ than you think. Water under pressure is a VERY persuasive force seeking out any weakness. Saltwater + electronics = disaster.
Chinese lights can work well, but are notorious for shoddy construction. Many of the “dive lights” are only splash and puddle proof, not suitable for diving. There are some that do work
The Ultrafire DV-S9 is decent and has been personally tested on a few dives. That does NOT guarantee it’s reliability over time. Typical of cheap lights this one may come with different LED’s or maybe even drivers. Of the 2 I have they absolutely have different LED’s. Construction seems OK. Anodizing is ‘pretty’ and not very good for wear.
I have one of these: U`King ZQ-X960 CREE XM-L2 1200LM Underwater 100m Diving Flashlight Torch - BLACK to compare. Almost exactly the same light but seems better made.
An advantage both have is the ability to use 18650, or 26650 cells. That also makes them larger but they can last more than a single dive. Most bright single cell 18650 are good for a single dive.
If you step up a bit this one has been shown to ‘go the distance’ in actual diving: Xtar D26 I know a couple active divers that have extensive experience with them.
There is also the Throfire TD26 as posted above. Seems good, no personal experience.
The DGX 600 has been shown to hold up amazingly well, and you get some support from a real US dive shop.
I’ve got a couple of these: SEA-CK TS100 XM-L2 U2 1000Lumens 4Modes Waterproof Diving LED Flashlight 50M
So far, holding up. Quite small, easy to stash. I find the switch suspect. I’ve had this kind of switch rust out in real saltwater use even with rinsing. First thing I did was take it apart and silicone grease the bejeezus out of it AND the screws. I always rinse it well and pump the switch a lot. I plan to repeat every 6 months or so with any dive use.
