led driver bypass?
Hi everyone,
In general, is there a way to bypass the driver and regulation and switch to direct drive by soldering points on the driver whilst using the same circult?
So perhaps a normal light will have 3 modes regulated (by clicking the tailcap), but by adding a second switch (soldering a bypass above?), now when the tail switch is clicked it will bypass regulation and output direct drive (becoming a full tactical light), so we can switch between regulated and non rregulated modes
Some lights like niteco have them by tightening the head
Cheers!
For some drivers, yes. Linear drivers can be switched to direct drive by switching led- to ground.
- add a switch/pushbutton into the head
  • wire it between BAT+ (Spring/Kontakt) on the Driver and LED+
    (so you bypass the whole electronic)
With linear drivers led+ is already direct to the led. Regulation occurs between led-and ground so that is where the switch would go but it must be a high current switch to handle it or some type of e-switch.
aaah - THX alot!
i looked once more at the layout (nanjg 105c) an you are 100% right!
sorry for the BS i posted….
