Guys i really appreciate everyones help.
I think i will bite the bullet and just replace it.
I acutally thought it would be a relatively simple job of just relacing the driver and led but guess not.
There are lots of very inexpensive 12V DC LEDs that you could try to replace the existing LED. No need for a driver, just wire them in with the correct polarity and use the switch but bypass the existing driver. I have a fairly large Christmas display, most of which has been purchased used. I wanted all of them to be lit with 12V LEDs in place of the incandescent lamps that came with them originally. You can wire directly to the leads on the LED. Here is a picture taken for a Christmas theme website showing many of of the bulbs used in my display.
The one six from the left is a 200 lumen chip-on-board G4 bulb It is small and has two bare wires coming out the base. I just looked up the price of just one shipped from China to the US and it is US$3.50 with postage. When I buy these things I never buy just one because the postage for 10 or 20 is the same as for one. BTW, the 3W 12V 200 lumen bulb is priced the same as the 6W 400 lumen bulb so if you want to increase the brightness go for the bigger bulb Cool white, dimmable bulb, 6W is $1.50 + $2.00 for shippinghttps://www.ebay.com/itm/224401685523
For size, know that the bulb on the left is a 10mm flat top LED.
Great solution. Though I have no clue how the beam pattern would be… But if he just want light, it has to be better than what he has now.
I really appreciate this.
I was actually looking at a g4 bulb but wasn’t sure it would work.
This is what I found.
Something similar to that.
Can you tell if that one has LEDs on two sides. I couldn’t. But they also have a G4 that lights on two sides.
Link
Which I would think will be better in a reflector.
How did you do this? Did you desolder the battery wires from the driver and use those?
And did you desolder the LED before doing the diode test and measuring the driver output? It may well be that both the driver and LED are faulty with one taking out the other, but it’s best to test them seperately to be sure.
That LED board looks like 20mm diameter? In which case, many 20mm diameter boards with LED pre-soldered are available. The only difficulty might be finding one with suitable spaces to put the screws back in to hold it to the heatsink.
So long as there’s space, you could order any driver that fits in the space, runs off 12V, and supplies the voltage/current your newly chosen LED needs.
I’d wait for others to confirm whether the above would work.
You could even go the extra step and order a coloured or high colour rendering index or UV led.
Obviously the quickest/easiest solution is to buy new, but there’s a sense of satisfaction in repairing (or upgrading) something.
Edit to add: what size is the LED hole in the reflector? Don’t lose the plastic washer/centering ring/gasket if there is one.
No bare LEDs that I know of operates directly on more than a forward voltage of about 2.7 to 3V. Any LED that you apply 12V to directly will fry. The ones that operate on 12V directly incorporate some way to drop the voltage to the correct forward voltage. The chip-on-board (COB) bulb has two COBs in the tip, one on each side and a driver in the base of the bulb. It is more efficient than individual LEDs in a bulb so you get more lumens for the same current. I’d suggest the 6W COB bulb if you can get it from eBay in your country. It’s cheap enough to try just for fun. The 3W version I have measures 11mm in diameter and 23mm base to tip, not including the wires at the base. Overall length is 30mm, end of wires to the top of the light.
I ordered a couple sets of 12V fairy light from a Chinese vendor and they instead sent one that worked on 5V. The connector was correct for 12V, not a 5V USB connector so when I applied 12V DC to it, the whole string lit brilliantly for about 3 seconds and then went dark. He admitted the error and sent me the correct product.
Have a look at the Cree XHP35 as an example of a 12V LED.
You are correct that this LED is designed to operate at 11.3 to 11.9V according to the CREE data sheet. I’m used to using the typical 3 to 5mm individual LEDs for Christmas decoration projects and you will fry any of them with 12V. The correct voltage needed also varies by the emitting color of the LED so mixing different color LEDs is complicated.
Thanks to everyone for the help and suggestions.
I ended up using a 1.6w G4 Led. 200 lumens. It will do for now.
The bulb is a bit big so not totally centre but will work for what I need it for.
Sorry for the crap pics.
