*Beamtech 1200 Lumens CREE XM-L T6 LED Rechargeable Headlamp with Battery Set
- Brand Name: Beamtech
- Bulb Type: CREE XM-L T6 LED
- Lumens: 1200 LM
- Mode: 3 modes (High > Low > SOS)
- Discharge time: 4 –6 hours
- LED life: 50,000 hours
- Input Voltage: 8.4V-12V
- Switch Position/ Type: Tail/Button
- Max Range: 300m
- LED Colour: White
- Color: Red,Black
- Case material: Durable aircraft-grade aluminum
- Lens: Toughened ultra-clear glass lens with anti-reflective coating
- Reflector: Aluminum Smooth/SMO Reflector
- Battery: 18650 lithium cell Pack,6400mA,Cable
- Charger: Input:AC100-240V,Output:DC+8.4V,50/60HZ,0.5AMAX,Cable Length:112.6cm/44.33inch
- Demension(mm): 44(D)x60(L)
- Packing Size(mm):200(L)x175(W)x60(H)
- Weight(g):440/620
- Package Includes:
1 x Battery Pack
2 x Rubber rings
1 x Charger
*Features:
- This torch uses of a XM-L T6 LED, producing very bright beam of light (1200 lumens)
- Extensive Lifetime of LED (10,000 hours) LED
- Attached with a Adjustable headband with a soft for forehead
- Excellent waterproof, suitable for outdoor environment, adverse weather conditions.
- The Many Uses of an LED Headlamp:Camping, Backpacking, Hunting, Fishing, Auto Emergencies, and Home Repair
- It is the top-level equipment for bike,fancier must buy it
- Three gears designed:High/Low/Suddenly and violently flash
- High light can last 4 hours,low light last 6 hours
- Apply to all kinds of bike,provide two kinds specifications rubber rings (4cm and 5cm )which is high quality ,Includes all handlebar diameter,very simple easy to use
Images:
