LED removed from star (accidentally)
I am just getting started in modding flashlights. I have two Convoy C-8 lights that I have been working on. I added some 7135 chips to both of them, which was a success. Then I decided to add larger wires to one of them. I was using a cheap 60 watt Iron, I got the driver too hot. Something way smaller then the 7135 chip came off of it. It didn’t work anymore after that. I got a new FX888D and a new Qlite driver. I had no problem adding 4 chips and larger wires to the new driver with my new soldering station (very nice). My new problem is that I ran the light on high for two minutes without the reflector on. This caused the LED to get too hot and slide around on the star (stopped working). I just ordered a XM-L2 on a Noctigon star. What is going to be my safe limit on run time while on high? What can I do to get more run time? Should I just remove some of the chips? I don’t know if I want to have to be worrying about damaging my light if I run it on high to long.
The led only slid off because it was on a non-DTP (direct thermal pad) star. Once it’s on a noctigon you can pretty much run it as high / hot as you like. It won’t desolder and slide off.
edit
Oh hey, Welcome to BLF! :beer:
If the led slid off the star the problem is likely the star wasn’t heatsinking properly.
You ran the light with the reflector off? Is that a light where the reflector is what keeps the star pressed to the body of the flashlight or pill? Is there thermal paste under the star?
FYI: You should be able to reattach the LED to the star pretty easy. Remove the star, place it in a pan in your stove (perhaps with some tinfoil between it and your pan), put the LED back in position. Heat the entire star until the solder under the LED melts. Remove from heat and cool.
You’ll need to properly heatsink your star to prevent it from coming off again though and as the previous poster mentioned a copper noctigon should help.
There may be another reason for which the LED de-soldered, which happened to me too. The use of so called LEAD-FREE solder, there are 2 types, one that has much much higher melting temperature than the common leaded solder and one that has ultra low temperature like 130Celsius, Bismuth-Tin solder. Since the Bismuth is so easy to work with I can see why many would use it for LEDs, especially since no one expects the LEDs to be over-driven.
It was the LED that the C-8 came with. The star is aluminum, it is held to the pill by two small screws. There was some type of gray compound between the star and the pill similar to glue, not very strong. I don’t know what type of solder was used on it.
The gray compound is thermal grease, it will not harden and eliminates air for a better thermal path.
Considering what you are saying I suspect the the bismuth-tin was used, because otherwise you would need a temperature of 183C for lead-tin solder.
Basically since the new era of LEAD-FREE requirements, many have started using bismuth-tin solder becasue the other types of commercially available lead-free solders need higher temperature than the lead-tin ones, so the bismuth-tin comes and kind of solves the temperature issue which people had with other hard to melt lead-free solders.
Ultra low temperature solder costs more, so how likely would it be to find it in chinese flashlights?
You sure screws where tight, star pressed down?
I can show you links to costs being identical between SAC and Bismuth-Tin, both lead free, but the bismuth based one will make everything so much simpler and faster for the fast workers.
Then, any chance you have a link for a small quantity? :bigsmile: I could use some.
I think this is cheap for 500g. I just hope you don't want to use some for soldering high power LEDs :)
http://item.taobao.com/item.htm?spm=a230r.1.14.26.Dt0BXs&id=14766493374&ns=1&abbucket=18#detail
I’ve never seen solder on a star melt simply from overdriving the emitter. This even for cheap Chinese made knockoffs. I think use of ultra-low temp solder is simply not done in flashlights. There’s no advantage to it so nobody does it.
I suspect the much more likely cause is that when the original poster was testing the emitter with the reflector off the star wasn’t pressed down into the pill so there was little or no thermal transfer out of the star.
I have seen it in front of me.
What is the no advantage over regular SAC?
I’ve seen it happen twice, for cheap Chinese 3xAAA lights (that had stars sitting in plastic heads)
I don’t know the root cause, but I wondered if I caused it by running it without the reflector or lens. I can tell you that I will not be doing that again. Hopefully the new LED with the Noctigon star and some arctic silver will not allow it to happen again. I am having fun and learning a new skill. The time that it takes to get parts to replace the ones that I screw up is killing me. :bigsmile:
That’s likely the cause.
To get proper heatsinking the star needs to be pressed firmly onto the platform behind it. In many lights the pressure used to do this comes from the reflector pressing down on a plastic isolator that then presses down onto the star. The screwed in bezel at the front of the light holds everything in place.
Without the reflector holding everything down, it is likely the driver wires lifted the star up slightly. This gap eliminated most of the heatsinking causing the LED to overheat.
It’s fine to test an LED light this briefly just to make sure it works. But for extended runtime, that star needs to be pressed firmly down.
The start is held down by 2 screws as the rking says.
Where are you ordering replacement parts from? There are some great resources in the US. Intl-outdoors or Mtn electronics for example.
Oops!
I missed that. Guess that’s not the problem then. Assuming rking didn’t remove the thermal grease when looking under the star, the problem may well be cheap solder combined with a thin aluminum star.
I have been getting my items from Mtn electronics. It is pretty fast considering it’s just about coast to coast shipping. I didn’t remove the star until after I had the reflow of the LED :8) I forgot to mention that Mtn electronics dedomed the LED before he shipped the light to me. Don’t know if that makes a difference. Even after I had removed the screws out of the star I had to use a small screw driver to get the star up. The thermal paste was holding it down pretty good. So most believe that I will not have anymore problems with the Noctigon star using thermal paste at 4.4 AMPs? Or should I consider removing some of the 4 chips that I added?
You should be fine with the Noctigon. Just make sure there is good surface contact between it & the pill.
